Oct 18, 2006 16:10:43 GMT
Just seem to keep seeing these around at the moment. Saw one at the garage that keep the Xantia in one piece and then saw another. I can't decide if I'd go bankrupt through petrol bills or garage bills if I ever got one.
Would like a Famillale though - except it's 300mm longer than the Xantia and therefore around the size of a super-tanker...
Graham
Oct 18, 2006 16:21:47 GMT
Yeah Special arn't they, but i know little apart from the genereal Citroen stuff, recon if cared for it would be ok, I'll leave that to the other guys who know more. in the meantime a link i came across. www.cxclub.co.uk/forum/
Shortcut
I won't be there when you cross the road, so always use the Green Cross Code.
Oct 18, 2006 16:31:02 GMT
not wallet busting if cared for but ALWAYS special
This space available to rent. Reach literally dozens of people. Cheap rates!
baz
Oct 18, 2006 16:32:01 GMT
I've had two....CX20RE and CX2500GTi....Properly looked after (by someone who understands them) they are an amazingly rewarding, and not especially expensive car to own and run.... I've yet to encounter a better car for FAST, long distance A-road and motorway work....Really impressive....But a pain in the bum in town....Not the CXs forte! ;D
Last Edit: Oct 18, 2006 16:33:39 GMT by baz
It IS as bad as You think and they ARE out to get You!
Oct 18, 2006 16:39:54 GMT
mmm ive been yurning for one of thses recently, the diesel2 seems to be a good bet. 35ish mpg and the early problems sorted.
If i got one then the stretched saloon version would be at the top of the list, i think its called the prestige.
J
Neil
Oct 18, 2006 16:40:27 GMT
The 'Prestige' model has the same wheelbase as the Familiale. Early CX's shared engines with the DS, so they aint as compicated as they first appear!
Tell me about Citroen CXBenzBoy
@benzboy
Club Retro Rides Member 7
Oct 18, 2006 16:46:06 GMT
I love CX's. I'd be tempted not to listen too much to the "armchair expert" types who will bang on about "complicated suspension systems" and all that (we all know the types!) - I'm pretty sure it ain't rocket science, and like has been said: if it's well maintained reliability shouldn't be an issue. Going to work in a space ship... who wouldn't want one?!!? ;D
Oct 18, 2006 16:56:58 GMT
/\ Thats what i learnt about Citroens too, theres no prob is you know what you are doing, still dare not get one but i will in the future. CX is teh win
stinkwheel
Doctor Of Gonzo Journalism - One of gods own proptypes, never even considered for mass production.
Oct 18, 2006 17:05:06 GMT
Right, I've owned 11 of theses.
From basic 2 litre to the 2.5 gti turbo. They are a special car.
ROT.....they do, like any citroen of its age. The panel work is not difficult to repair or replace and even the chassis lonegerons can be replaced. Its not a body on chassis construction though, despite how it appears, don't try and seperate the two something will fold up.
ENGINES....... go for what you need, 2 litre ohc seems slow in such a big car but can be deceptive, the 2.2 ohc is a lot better and is all you will really need day to day and is probably the best on fuel too. 2.4 or 2.5 inj are a good lump and will run for 250,000 miles with little more than routine servicing if they are not treated badly, the turbo's both petrol and diesel are very special, they turn the CX into a fast spaceship. Ignore stories of porus blocks on the turbos diesles, they have all been sorted out by now. On the 2500 injected engines they have either one or two crank position sensors, these can go open circuit when hot, pain in the neck and more expensive than other crank sensors to but but easy as pie to replace.
HYDRAULICS...... no problems, gen up on the theory behind them and in principal are easier to work on than sprigngs and dampers and make for a very good middle ground of comfort and handling, you will want to drive one before buying due to the DIRAVI self centralising fully powered steering, yes, you let go of the wheel and it will return to centre on its own, can lead to some fun initial manouvers but once learnt is like second nature and you will think all cars should have it.
The CX in any form will not cost anymore to run than any other old car, unless you buy a really rotten one. If you want any more specific advice just ask. Familialles are good but a safari is more practical if you don't really need all the seats.
Last Edit: Oct 18, 2006 17:07:01 GMT by stinkwheel
1973 Citroen Dyane 6 1980 Citroen Acadiane 1992 Citroen AX 1990 Citroen BX 1997 Citroen XM 1993 Citroen BX 1997 Citroen Xantia 1977 Citroen Ami 8 1996 Ford Escort 1989 Citroen BX 1997 Suzuki RF900 1988 Yamaha TDR250 1979 Honda CB400. 'I need less vehicles'
RetroMat
Column Shifting!
Oct 18, 2006 17:24:20 GMT
Oct 18, 2006 18:53:00 GMT
Not complete without andy saunders
Tarka
Oct 18, 2006 20:36:19 GMT
I love em and that green one is just like my mate's dad's one he had when we were kids.
Sharks in the garage.🐬🇩🇪 I'll finish my projects when you've finished your's!😎😜
Oct 18, 2006 21:18:23 GMT
HYDRAULICS...... no problems, gen up on the theory behind them and in principal are easier to work on than sprigngs and dampers and make for a very good middle ground of comfort and handling, you will want to drive one before buying due to the DIRAVI self Yeah, I must admit that the Xantia has totally convinced me of the benefits of the wierd hydraulic suspension set up... it's so smooth and lovely and doesn't seem any more or less grief than springs and dampers... Graham
