As title really. It's lowered on coilovers. When I go over pot holes or bumps, there's a knock coming from the passenger side rear suspension. I don't think it's the exhaust knocking so I'm thinking bushes but want to be sure. As it's lowered I know it will wear out bits quicker than usual.
Any ideas?
Probably the top mount - open the boot up, take the cover off and bounce the car up and down, see if there is any movement in it.
Will do. I'll check the top mounts and I've been told (many times now) that if a Golf is lowered, the exhaust will bounce on the rear beam (causing n/s rear knocking) so I'll give it a good once over saturday and replace the exhaust rubbers. Are the top mounts a hard job? I've never done top mounts but there's a first time for everything
They're pretty straightforward
Never had a problem with the exhaust knocking personally, but I could see how it's possible
tome30
Mar 10, 2012 15:51:16 GMT
I know this sounds obvious but i had this exact problem. It was the exhaust bouncing up and hitting the body. Try it get the exhaust and rush it up, youll hear the same noise.
tome30
Mar 10, 2012 15:53:18 GMT
I should really read previous posts.
