This evening I started to fit wide arches on my Passat b4 I got from eBay. After some browsing on Google I found out aprox how I should start the job, and with some fiddeling with the first one (the only one I have done so far) I went into some problem.
After I have cut the metal to make the arch bigger and wider on the front wing, I find some challanges with the inner mudguarg wing because the arch on that one is much more smaller than the new arch I have made.
So how does you solve it?
I have tought about maybe sort it with some fiberglas due to the inner mudguarg is made of plastic - or are there any other solutions who is better?
