Oct 15, 2006 17:57:34 GMT
Hi I need some new rear springs for the Viva as it's very stiff at the moment I know next to nothing about suspension so I need to know how I go about ordering some softer springs and where to get them from. How do I work out what kind of springs I need to make it softer? It's got Spax shocks if that makes any difference. I'm going to Scotland in it for two weeks next month so I have to get it sorted by then. Cheers
Last Edit: Oct 15, 2006 18:00:09 GMT by Deleted
Aaron
Oct 15, 2006 18:30:18 GMT
I can't remember the formula, but spring stiffness depends on the diameter of the wire it's made from, the diameter of the coils and the number of coils. To get a softer spring, reduce wire diameter, increase coil diameter (not really possible on a car) or increase the number of coils. I don't think it depends on anything else - maybe someone else will have a better memory than me?
Aaron.
1975 Toyota 1000 with 4A-GE (tweaked a bit)
1992 Nissan GTi-R (now sold after 17 years)
2001 Subaru Impreza WRX (remapped)
Oct 15, 2006 18:36:38 GMT
Hi I need some new rear springs for the Viva as it's very stiff at the moment I know next to nothing about suspension so I need to know how I go about ordering some softer springs and where to get them from. How do I work out what kind of springs I need to make it softer? It's got Spax shocks if that makes any difference. I'm going to Scotland in it for two weeks next month so I have to get it sorted by then. Cheers Have you tried adjusting the dampers ? They may be set up too stiff Have you tried putting something heavy in the boot to see if the ride improves ? If the springs are too stiff the ride will improve with weight in it. South yorkshire springs will make some for you if you need them ? Cheers Dom
Oct 15, 2006 18:58:57 GMT
i thought vivas had leaf springs on the rear if so manchester springs in old trafford can make you some softer ones
slater
Club RR Member Number: 78
Spring help neededslater
@slater
Club Retro Rides Member 78
Oct 15, 2006 19:03:38 GMT
Id take a guess at it being the shocks that are the problem not the springs. Deffo worth a look!
Oct 15, 2006 19:36:44 GMT
i thought vivas had leaf springs on the rear if so manchester springs in old trafford can make you some softer ones Nope it's got coils all round ;D I will try adjusting the shocks, I did notice a little screw at the base of them, do I just turn it anticlockwise to make it softer?
Oct 15, 2006 20:06:29 GMT
i thought vivas had leaf springs on the rear if so manchester springs in old trafford can make you some softer ones HA`s did I think, and I am probably wrong here but did they also have a tranverse leaf on the front or was that only on vans
