Anyone know these at all ?
got one in that basicly refuses to run 99% of the time and when it does it will only idle, checked the lift pump and it's pumping up to the filter and if I crack s fuel injector fuel will come out but it seems rather low on presure? not exactly gushing out when I crank it over.
I've changed the filter, and CPS, theer's no swarf in the filter and the shut off valve appears to doing it job (removed and tested) tripped and reset the fuel shut off switch and there's a live at the shut off valve.
I don't have a noid light so I cant check the injectors are firing but though somone might know a problem with these other than those i've checked ?
I know it's not retro so have some retro pugs for you delectation ;D
ha ha just noticed and changed the header, funny how changing 1 letter can still describe the same motor
