Feb 22, 2012 15:56:24 GMT
Hi All,
So, I'm using an old twin cam head from an engine that died a few years back on a new project engine for one of my motors. Now the reason for using this head is it has new valves etc as I had a cam belt snap! The problem is the head has been sitting in the garage since the engine blew the bottom end and so its grim dirty! It needs a damned good clean out but I'm unsure as to how to go about doing this as the valves and springs are still in place! the Tappets I can remove no issues and the Cams are not in anyway.
Can I just steam clean it as it is or will that do bad things to the valves and their relevent springs?? any advice would be appreciated.
Cheers Rich ;D
Feb 22, 2012 17:02:59 GMT
Personally I'd dismantle and clean each part seperate but if you have access to a steam cleaner then used that. Worse that might happen is components could start rusting so give them a quick spray with WD40. Just be careful that when cleaning you don't do it on the floor so that crud will get into the passageways or if on a bench etc then it doesen't get knocked to the ground. Of course a manual inspection and blow though of oilways with an airline before fitting is recommended. I believe a dishwasher would also do an excellent job paul H
Feb 22, 2012 17:19:25 GMT
I think if i put it in the dishwasher the wife would probably throw the bloody thing at me!! cheers for the comments! Paul
dgo
Feb 22, 2012 17:53:19 GMT
One or two of those cleaning and freshening tablets through afterwards will she ever notice?
Feb 22, 2012 19:57:38 GMT
I can vouch that it does hurt when your wife throws something at you after using the dishwasher not to wash dishes!
Also, even a tiny amount of engine oil goes a VERY long way inside a DW! Ours never really recovered and the white plastic was forever a dull shade of grey. A constant reminder for me of the error of my ways every time I used the DW!!
Having said that it did a cracking job of cleaning the car parts!! If I were regularly rebuilding engines I'd look on fleabay or gumtree and see if I could pick up one cheap.
Feb 22, 2012 20:19:49 GMT
Try and find a friendly engine builder with an acid dip tank where you can leave it for half a day
Feb 22, 2012 20:21:19 GMT
I'm often tempted to see if I can scrounge a tatty but GWO old dishwasher (Freecycle ?) for the garage ;D
paul H
Feb 22, 2012 20:32:21 GMT
Bio washing powder is very good for cleaning oily parts, just wear gloves when using it!
I've got Rovers.
Feb 23, 2012 10:29:14 GMT
I wash my parts with brushes, steelwool and bio diesel in a pump-sprayer. In a plastic tub. Bio diesel (the real stuff, not SCO/WVO ;D) is a good detergent. But wear a GOOD respirator! And covere everything in old clothes; it stinks like hell ;D Final rinse with brake cleaner and all is shiney Mini gearbox & transfere case for example: I'm not using the dish washer anymore. The water dries off too quickly and leaves marks. Also I have the feeling that greasy gunk get'S just distributed, not washed off. Maybe I've used the wrong chemicals? Anyway; aluminium & normal washing powder (for dishes) etc. is NOT a good idea ;D Don't ask... I'm not cleaning my parts with water again. Only bio-diesel & brake cleaner, the old fashioned way.
dungbug
'Ooligan!
Feb 24, 2012 23:23:15 GMT
Immerse it in Paraffin overnight, then use a soft/medium brush to clear off the gunk. Used this technique on a Bug engine a while back with good results.
If anyone wants an old DW, I've got one going spare which came with my house - come and collect from Brough, near Hull, east Yorkshire. PM me.
HELLO TO BROUGH!!!! I'm in elloughton! Lol This dish washer? Is it just cold water feed or does it need a hot water feed? I know Nowt about dish washers.. Hang on, you've got a pm
