Confused
Building: Anglia 105E with 6A13TT
Nov 21, 2020 13:17:26 GMT
​Whoops, forgot to post up the next videos!
In Episode 20, I find out what I've broken with all the wiring changes:
And in Episode 21, I see whether the car will start!
Confused
In Episode 22, I finish off the brake/clutch systems, and start to make plans about modifying the cooling system.
In Episode 23, I need to make some new engine mounts to free up space to relocate the radiator.
Confused
​ Haven't posted latest videos for a while (in case anyone here isn't yet subscribed on YouTube!)
In this set of videos I make changes to the engine cooling and inlet air cooling systems.
Confused
In a bit of a change of pace, I try to cross a few outstanding tasks off my white board full of outstanding tasks!
Confused
I've spent most of the time between last episode and this working on redoing the radiator modifications. So in the absence of anything else, here's a slightly shorter video with an update of where I've got to.
great diy swaging solution
87 manta redtop quantum 2+2 1973 mini xe'd mk4 astra van
Confused
Mar 27, 2021 14:47:42 GMT
In these two episodes, I try (and fail) to get the car outside, but then succeed!
Confused
Apr 12, 2021 15:43:53 GMT
This time round, I investigate what is going on with the clutch, after finding last time that it wasn't quite working right. Will I need to remove the engine *again* to sort it out?
Confused
Apr 23, 2021 19:06:01 GMT
In this episode, after the success of getting an MOT test and the car being road legal again, and the sadness of a burnt out coilpack connector and suspected failing engine, I fix the coilpack connector, and begin troubleshooting where that horrible knocking clunky noise is coming from.
Confused
In episode 33, I replace the banana-shaped driveshafts, and further investigate the horrible knocking noise coming from the engine.
I've done something a little different this time - an unedited "first person" segment - please let me know if you like it, and would like to see this kind of thing again!
Confused
May 21, 2021 18:31:48 GMT
There's finally a break in the weather long enough for me to get the car out for a test drive in the Anglia! But.... it's never that simple, is it?
Confused
This time round, I do some fixes & tweaks based on last episode's test drive & subsequent discoveries about my four cylinder V6 engine...
Confused
Jun 18, 2021 18:35:09 GMT
I've got lots of stuff going on around the house and garden, so not quite as much time to work on the Anglia - however, I did get the exhausts fitted back up, fiddled off-camera a little with the Oxygen sensor display thingy I've been building, and managed to get out for a bit of a test drive & start the road tuning.
Confused
In this episode, I try to make the interior a little nicer, and quieter, with the addition of carpet and some underlay for sound insulation.
Confused
Jul 31, 2021 14:32:24 GMT
In this episode, I pull out a smoking turbo, do some wheel alignment, and go out for some more test drives.
Confused
Jul 31, 2021 14:32:36 GMT
In this episode, I start to look at the noise coming from the rear end of the car, and finally start to swap out the differential I didn't fit last year.
My step-dad also pops in to lend a hand.
Confused
In this episode, I continue fitting up the rear diff, make a stupid oversight that costs me hours of time to correct, and replace the front brakes with shiny new stuff!
Confused
In this episode, I finish putting the car back together, and go out to see if the new S14 differential and front brakes have made any difference at all to how the car drives, or if it was all a huge waste of time!
Confused
Sept 13, 2021 17:06:21 GMT
I've been busy integrating a lot of my dad's old tools and equipment into my home garage, so no progress on the Anglia this time. So, instead, I thought I'd give you a guided tour of the newly rearranged and tidied garage - as you'll probably never see it this clean and organised again!
Confused
Sept 24, 2021 19:54:43 GMT
I've been talking about it for ages - but in this episode, the Anglia finally makes it onto the dyno!
So - how does it turn out? Did it make decent power? Did it all explode in a big fireball? You'll have to watch the video to find out!
