Confused
Building: Anglia 105E with 6A13TT
Feb 29, 2016 10:55:10 GMT
Adjusting the handbrake helped with the noise and temperature, but the rear wheel bearings still needed replacing, so I stripped down the rear end to remove the bearings. And then went a bit further... I figured whilst I was there, I'd remove the rest of the brakes and tidy up the backing plates and calliper carriers. Continuing with the process of trying to eliminate noises, I found that the throttle cable was tapping against both the turbo heat shield and underneath of the bonnet. So a couple of extra cable ties will secure it better and stop it making a noise. Since I fitted the new radiator, I didn't like that it was visible from the front of the car. It was slightly too tall, but extra size is needed for the cooling capacity, so a section of the front panel beneath the number plate was removed. But, as the radiator was bright shiny aluminium, it stuck out like a sore thumb, and I was frustrated with it. So I finally got round to disguising it with a squirt of black paint. And, finally, there's a nice shot from the front, so here's one from the back too. And last but not least, the interior as it currently stands, with the new ETB boost gauge.
Confused
Apr 16, 2020 14:04:35 GMT
Soooo, it's been a while since I last updated this thread! How time has flown by!
I've done many a things to the car since then, but have been rather remiss in keeping track and documenting them!
I've now decided to do something I wish I'd done years ago when I started this project, and film it!
I'd really appreciate it if you could watch, like, share, subscribe etc, and feel free to continue to ask questions here!
Confused
Apr 25, 2020 15:41:38 GMT
Here's episode 6, I finish tasks started in earlier episodes, so I can get the car ready to take for a new radiator to be made.
Confused
May 10, 2020 16:18:20 GMT
Episode 7, where I pull out the rear differential
Confused
May 24, 2020 17:33:08 GMT
Here's the next installment, when I remember that there's differences between the S13 and S14 diffs...
Confused
Lost of time go into these videos with setting up cameras. audio, then editing. Thanks for taking the time.
Confused
Yes, it does slow the whole job down quite a bit! But, it is good fun, and I'm enjoying the process of making the videos
Confused
Jun 19, 2020 19:26:54 GMT
Into double digits!
Confused
Episode 11 of Garry's Garage is live! I didn't realise at the time that this was the start of quite a large rabbit hole I have led myself down!
Confused
Jul 20, 2020 19:47:41 GMT
In episode 12 of Garry's Garage, I get my Wilwood pedals installed and mounted nice and securely.
I apologise for the poor audio quality in parts of the video.
Confused
In episode 13, I fabricate some brackets to hold the brake & clutch switches, and do some copper pipework.
Confused
Aug 16, 2020 13:32:31 GMT
In episode 14, I get a little extreme, and delve deeper into the tweaks!
Confused
Sept 1, 2020 18:23:44 GMT
In episode 15, I finish up the bulkhead metalwork, and move the fuel tank into its new location.
Sept 7, 2020 14:31:27 GMT
I missed this build in its entirety somehow! Huge build. Very different. Love a sleeper. Shame the pics are so bloody small.
Confused
Sept 15, 2020 14:47:08 GMT
Thanks @quickrack1 . I had to change all the photos to clickable thumbnails as the bandwidth used by the full size photos was getting quite high!
But, if I get some time, I might go back and change them to the full-size ones, I've since swapped hosting so the full size images won't be a problem any more.
I do have another video though!
In episode 16, the fuel and braking systems get mostly completed.
Confused
Sept 25, 2020 19:07:37 GMT
In this episode, I tackle the heater, and it gets a massive upgrade from what I had before!
Confused
In episodes 18 and 19, I begin to tackle the wiring (again)! It's quite a daunting task, and I've already had a couple of attempts at it over the years, so was very messy!
Use the site uploader. It's easy. My phone hates the thumbnails and video links.
mat88
Yorkshire and The Humber
Just read this from start to finish over a few days. And it's brilliant! I love a daft engine swap. And this couldn't get much dafter. I thought I was short on space under the bonnet. But this takes it to whole new levels. (Will watch the vids when I'm not at work)
Bookmarked
