chrisf
Feb 19, 2012 12:28:15 GMT
Hi, can anyone tell me if there is any difference between the dashpot and damper sizes between HIF38 and HIF44 su's? are they different or is the only difference the bore size of the carb mouth?
i have most of a 44 but need the dashpot and piston, which i can get from a cheap 38 if they fit...
thanks
Feb 19, 2012 13:05:25 GMT
Nope, they are bigger.
'83 GTM Coupe. 4A-GE Powered '00 GTM Libra Auto. Ick. '71 Detomaso Pantera. Current Resto '89 GMC Safari Tow/Kip bus '05 SAAB 9-3 Daily '71 Siva Moonbug. Not even contemplating resto yet.
chrisf
Feb 19, 2012 13:15:25 GMT
dammm! ok, thanks for the info
Feb 19, 2012 14:17:26 GMT
The piston is smaler on the 38, dashpot is the same and also interchangeable between HS and HIF types. In fact, early HIF carb's didn't have the roller bearing dashpot/piston assembly and very late HS carbs got the roller bearing assembly too. The roller bearing dashpot/piston assembly is the one commonly refered to as the 'HIF' type... It's the better choice, as it's much less likely to stick As far as dampers are concerned, there'S a lot of different dampers about, take the damper that came off your engine. They can have quite some effect! My laptop should be repaired by the middle of the week, I could upload all the SU carb reference stuff I have if you need to find the correct damper & spring. But it's all on the oder HD... So basically two options: find a HS6 or HIF44 dashpot assembly. Swapping pistons between dashpots can be done, but is not recommended.
