Feb 19, 2012 11:48:54 GMT
Are there any formulas out there ? Any advice available from other similar weight/layout cars ? All new system going in the the GTA .We are losing the servo and installing pedalbox with bias valve . I have new bigger 4 pot calipers but need to spec masters to suit . std kerb weight 1180 ,450kg front axle ,730 rear
Feb 19, 2012 22:58:06 GMT
Personally I would look at .725 fronts and .625 rears,as you are using a peadl box you can adjust the front rear bias to suit.
Prc
RobinJI
There's a good guide here for exactly what you're wanting to do, the only issue being that it needs you to know the centre of gravity height, but an educated guess would give close enough results that it'd give you a decent starting point at least. That article comes from here, there's quite a few interesting and informative articles there about various braking related things.
Last Edit: Feb 20, 2012 8:30:35 GMT by RobinJI
Feb 20, 2012 15:25:12 GMT
Excellent ,thanks both .I really want to try and get it right first time ....well at least design it so I can tweak it enough to work well without buying new parts .
Last Edit: Feb 20, 2012 15:26:02 GMT by ratmangta
John
Feb 21, 2012 17:16:09 GMT
Fred Phun brake handbook gve me all the calculations I needed to calculate the master cylinder sizes. Quite easy to follow too but you do have to estimate a few values (C of G as per the other post).
