Copey
I am gonna black the bumpers on my Saph and was wondering what would be the best way to do it I have used plastikote plastic paint on smaller plastic parts with no problems, and I have seen a load of special plastic paints but is it really needed? if I key well would normal Halfords primer and satin black do the job? opinions and recomendations please
Last Edit: Mar 12, 2012 15:32:29 GMT by Copey
You really need to use a proper plastic primer - Avoid the cheap stuff or it'll all be coming off in no time. Also, make sure you spend ages cleaning the bumpers first to remove any traces of back to black silicon sprays. Plenty of scrubbing with a stiff brush and washing up liquid, followed by a good jet washing will probably do the trick.
If you just want to paint the bumper black again, just ask at a refinishing supplies place for "Impa bumper paint"
They can mix it in loads of colours, and it's designed exactly for this. It keeps a textured finish but doesn't fade, and it sticks really well and is pretty easy to use. I've used it to paint the doorcards and dashboards on t4 campers, and you'd really not know they had been sprayed. I always get it by the half litre/litre and spray it from a gun, but I reckon most refinishing supply places would be able to put it in aerosols.
Copey
Feb 14, 2012 12:09:14 GMT
nice one, cheers, the bumpers have never been back to blacked, so makes that easier will give em a damn good clean any ways and a good key, the impa paint sounds like a winner thanks very much
Feb 14, 2012 12:14:34 GMT
Best way to clean anything before painting is to use panel wipe. As for plastic primer I use Octoral plastic primer which is 1k, so you just pour into the gun & blow.
bortaf
Feb 14, 2012 12:15:10 GMT
TBH i've never used plsticote or any plastic primer, decent red oxide and a top coat, i do all the plastic parts that way never had any lift except where i havn't prepped propperly ?
R.I.P photobucket
Feb 14, 2012 15:28:42 GMT
I've used Halfrauds plastic bumper paint on my last 3 motors. I know it's Halfrauds but I was very pleasantly surprised the first time I used it on my old Breadvan. I'd tried everything to get them black as they'd gone grey with age and I just spotted it one day.
I was very aprehensive as it says on the tin that you don't need primer. There's a clear bumper preperation spray which you use on the bumper first, similar to panel wipe. You spray it on and wipe it with a clean rag, then you just paint it. It dries really nice and I used it on my Metro and I painted the bumpers and bodykit on the GTI.
It's probably the best thing I've ever bought from Halfrauds, ever.
Copey
Feb 14, 2012 19:55:41 GMT
yeah, i did spot the halfords paint but wondered if it was too good to be true, it does sound like the most simple (aka lazy) option, so i will go for that, thanks mate
fogey
Feb 14, 2012 22:30:05 GMT
TBH i've never used plsticote or any plastic primer, decent red oxide and a top coat, I do all the plastic parts that way never had any lift except where I havn't prepped propperly ? red oxide - that'll stop the plastic rusting . . . Seriously though folks, I've also used the Halfords Plastic Primer witout problem.
Copey
Feb 14, 2012 22:37:48 GMT
thanks for all the input lads i will post the results as soon as i am done
rodney
https://www.facebook.com/RD-vehicle-transport-and-recovery-services-525622614268010/
I've used Halfrauds plastic bumper paint on my last 3 motors. I know it's Halfrauds but I was very pleasantly surprised the first time I used it on my old Breadvan. I'd tried everything to get them black as they'd gone grey with age and I just spotted it one day. It's probably the best thing I've ever bought from Halfrauds, ever. i have to agree with you i used the bumper paint a few times and its excellent and lasted well:)
facebook: rodney dean / rd transport
Glad l read this got roof bars on our 2006 sedona which have gone grey so i'll get some of that Halfords stuff ;D
All the bumpers I've used it on were textured, if I ever end up doing something smooth, I'd still key it with some fine wet & dry to be on the safe side before using the prep spray and paint.
rodney
Feb 16, 2012 22:56:03 GMT
wet and dry or a scotch pad will do it, then bumper black paint ,.
Feb 20, 2012 14:41:08 GMT
Feb 21, 2012 16:37:34 GMT
That's the stuff. It's in a pink/silver tin now though, they must be the old type tins.
bmboy
great age!
Feb 21, 2012 19:49:00 GMT
If you wanted to push the boat out you could sand it flat first, then use a plastic primer.
Skoda Estelle 120l x3 Skoda Favorit Triumph Dolomite Mercedes-Benz 190E BMW 635csi BMW 528I Volvo 850 Mercedes-Benz 230TE Skoda 136 Rapid
Feb 21, 2012 21:39:23 GMT
they look as if they were black plastic already?just faded? best stuff in the world in my opinion is Hilite by concept chemicals, just paint it on and leave it for a hour or so, come back wipe excess off and the bumper is like new, goes for any coloured plastic or rubber it just soaks in and brings them up like new, been using it for years! for instance i had a 1986 shogun here today which has never been touched on the bumpers or plastics etc, they were faded to grey and dirty and discoloured, painted it on and two hours later when the guy came back he thought i had put new bumpers and plastic surrounds on!!
Copey
Feb 21, 2012 22:38:33 GMT
rwdrules, cheers for that, but they are gettin painted, i have used all kinds of things on other cars in the past, from the expensive to the cheap, some last longer than others, but eventually it goes grey and needs doing again, would rather just paint em and have done for a year or so rather than a month or so
Copey
Mar 12, 2012 15:31:48 GMT
Last Edit: Mar 12, 2012 15:32:04 GMT by Copey
Aug 13, 2012 18:29:11 GMT
Hi FYI if you have faded black plastic bumpers if you blow a hot air paint stripper at it it will bring the oils inthe plastic back to the surface!!
I would be rich if i had not spent so much money on Cars and fast women...oh, i did waste some of it as well!
