rob0r
East of England
Club RR Member Number: 104
Feb 10, 2012 18:42:20 GMT
I stupidly cracked the rear screen in my E32 735i putting a wheelbarrow in the boot and it touched the glass. There are loads of large cracks running from the middle of the bottom of the screen reaching across 3/4 of the total screen. The screens totally had it but E32 screens are bonded in and I don't have a spare. I need to keep using the car for the time being until I can source a screen (or a donor car ), so I'm looking for ideas of reinforcing the screen. It's lasted a week so far in the freezing weather, I thought it would have smashed through driving stresses or water ingress and freezing conditions by now... Could tint or some sort of window laminate be used for this? I could use duck tape I'd hope not to revert to that...
E30 320i 3.5 - E23 730 - E3 3.0si - E21 316 M42 - E32 750i ETC
Feb 10, 2012 18:50:28 GMT
You can get window tint megacheap off ebay (£4 for enough to do both sides) and I'm sure that would hold it in one piece for the time being
Feb 10, 2012 18:58:36 GMT
Why not "bite the bullet" and pay the insurance excess seeing it's going to probably be a professional job to fit even a secondhand item ? Doesn't affect NCB.
Paul h
BiAS
Insert witty comment here
Club RR Member Number: 147
Feb 10, 2012 19:04:56 GMT
You won't stop it getting worse unfortunately Rob, if it's cracked not crystalised that would suggest that it's a laminate not toughened. Has it cracked the inside or the outside layer or both? If it's laminate the plastic layer in the middle will stop it leaking/falling in/exploding next to bus stops full of nuns carrying kittehs. Mates screen on his escort van cracked right across the bottom after a stone got kicked up by a lorry on the way back from the MOT, he only changed it for the MOT the following year because he had to. We used to draw a mark at the end of each of the cracks radiating out from the impact with a sharpie whilst sat in traffic on the way home from work, just to see how it was progressing. All the cracks stayed in the bottom 3" of screen so visibility was never impaired. Tint or laminate would hold it together if it did decide to let go but to put the stuff on you'd need to press on the inside of a concave window, which in theory is its weakness. Even on the outside I'd be scared I was going to make it worse. I've cracked a couple of Ford 'screens in the past just putting the stupid stick on interior mirrors back on.
(car+wheels)-rideheight=WIN
rob0r
East of England
Feb 10, 2012 20:10:08 GMT
Cobblers - I think if I do anything, this is the route I'll take. It will make the 7 look even more "drug dealer" Paul - I don't think my insurance would cover it since I'm TPFT. Apart from previous screen claims I've found comprehensive insurance isn't worth the hassle, I just end up fixing my cars anyway! Ian - I hope you're right, I know nothing about the screens so if the screen it's laminate in the middle and isn't likely to instantly collapse then I'm happy to leave it for a long time. Since it's the rear screen I couldn't care less!
john61
just give in to it
Feb 10, 2012 21:40:13 GMT
clear sticky back plastic ?? temp repair for now
Porsche 911 SC VW T25 SYNCRO BSA C 15 HONDA CBR 1000
Feb 11, 2012 16:33:15 GMT
screen flat? - silicone a sheet of perspex to it, or even a piece of plywood...
omega
Feb 12, 2012 15:38:27 GMT
if you want to stop a crack spreading there is only one way you need to drill a small hole at the end of the crack as a crack cant jump a hole.
omega
Feb 12, 2012 16:33:46 GMT
