Mr K
those re drilled fiesta discs in that kit look perfect - when i looked at the pics of Js i thought they bolted to the back of the hub - not going over the front like they actually do! are the discs available on their own? as i don't need the rest of the bits.
Nick
fiesta discs you can get at probably any local factors,you just need to find a friendly machine shop to redrill the pcd etc.
fiesta discs you can get at probably any local factors,you just need to find a friendly machine shop to redrill the pcd etc. You only need to slot them If you have nothing better to do a big Vice and a file will have the same result
Mr K
fiesta discs you can get at probably any local factors,you just need to find a friendly machine shop to redrill the pcd etc. You only need to slot them If you have nothing better to do a big Vice and a file will have the same result are you guarenteed it will fit centrally though if you do it this way? Also, is it mk1 discs? as none of the ones on ebay look right?
