I've finished all the welding on my GTi-R and have new front wings ready to fit, but a lot of the plastic clips and so on for the arch liners etc are missing/broken.
I need the following parts
Nylon blocks that fit into a square hole in a metal panel and then have a self-tapper screwed in.
Plastic "scrivets" - two piece items, you push the outer piece through the two parts to be joined, then screw the second piece into the centre, which spreads the first part and holds the two panels together.
Anyone recommend a supplier?
Cheers,
Aaron.
Cheers,
Aaron.
