iane
Mar 24, 2012 15:40:59 GMT
Update : Managed to buy a second hand fuel tank locally, so that'll go in soon. Still no suspension so she remains on axle stands for now. (should be next week) New Sony CD/radio fitted. Although I will fit something more suited later. General tidy up of interior and boot. Fixed the passenger elec window, so all windows now work ok.
Last Edit: Mar 24, 2012 15:43:01 GMT by iane
iane
This arrived today :-)
Last Edit: Apr 26, 2012 22:11:16 GMT by iane
Mar 28, 2012 19:04:24 GMT
Cant wait to see those on
iane
Second hand tank now fitted along with all new fuel hoses, etc. Front susp is on but the rears require e28 rear top mounts. So I've ordered some from BMW. Hopefully all will be done mid week. New discs and pads also fittted. All brakes bleed... [/url]
iane
Got the susp all on now. Details of fitting to follow but for now... Just needs a clean and somebody with a good camera!
Tarka
That's a great sneaky shot - go on give us some more. It's looking nice and low now - wasn't sure about the 17s at first, just think they are a little too big but seeing it lowered might change my opinion! What make is the sus and are they coilovers? Cheers.
Sharks in the garage.🐬🇩🇪 I'll finish my projects when you've finished your's!😎😜
Definitely want to see more
Looks great from that shot
iane
No more pics until its clean. I haven't washed it since I bought it, so it needs it!
Its on staggered 18" BMW Style 5s not 17's!!!(8x18 front and 9x18 rear) And yes they are coilovers from a company called RPM. They are made by GAZ though and require e28 rear top mounts.
Proper pics soon...
iane
Definitely want to see more Looks great from that shot I took that with my HTC phone before going home tonight. More soon!
Tarka
Ha just realised they are 18s!!!
Very nice mate.
Instagram - Woodym3evo W114 M104 69 Merc 1 Series 135i M-Sport #thegovernorsclub #TeamAF #baggedbenzuk
Nice looking car dude, you cant beat an old beemer.
Mark
Drop me a PM once you've thrown a bucket of water over it and I'll drop by with my SLR and take some snaps.
Looking very nice.
E36 BMW 318is saloon (rare as a hens false tooth) VW Caddy Maxi 2010 (usually full of Labradors)
Whats the width and offset of the rear wheels, I always thought that Style 5's were too tight under the rear arches to lower it like you have Looks like I might be just about to rethink my wheel choice
hak074
Oooh, you tease ;D
How good does that look, even just from that one pic. The edge of the seat is getting a work out while I wait for the next lot of pics!
iane
Thanks for the comments!!!
Fronts : 8x18 et20 on 205/40/18 with 10mm spacer.
Rears : 9x18 et22 on 235/35/18 no spacers.
Had to roll the rear arches though!
iane
Couple of details of installing the coilovers... Fronts : Front struts were sent away so that the coilover section can be welded onto the hub section. Standard top mount used and fits great. I might fit camber plates to the top mount to add a little more camber but that's later. The only issue was that the standard strut had a bracket for the brake lines. The coilovers came with a bracket but wasn't designed for a the brake lines. So I made a square bracket and drilled some holes... Bracket is the shiny part and is bolted to the coilover bracket. Sorted. Rears : Rears require e28 rear top mounts and a 3.5mm spacer at the bottom. Difficult to see but you get the idea... Could also do with assistor springs if you want the ride height as low as I have it, as the spring is loose when jacked up! Will give GAZ a call about that tomorrow. Car has been washed, clayed, machine polished, waxed and is looking good. Full pics tomorrow...
iane
Love it mate.
That's one of the coolest Beemer's ever,the color,the chrome,the stance,I its mint.hmm e46 m3 running gear.
