tigran
In rust we trust. Amen.
Club RR Member Number: 142
Well popped over to a mates house to get the project allagro running. No such luck. Anyone care to listen to the symptoms?
We got it to turn over once, but after that every time you turn the key to fire it up there is a loud click and everything dies, lights the lot. You have to disconnect the battery and reconnect it in order to get any lights on the dash etc etc.
Thinking now is that it might be a shagged starter - thoughts?
Thanks for any advice
stinkwheel
Doctor Of Gonzo Journalism - One of gods own proptypes, never even considered for mass production.
is the battery good? sounds like it might be shagged.
1973 Citroen Dyane 6 1980 Citroen Acadiane 1992 Citroen AX 1990 Citroen BX 1997 Citroen XM 1993 Citroen BX 1997 Citroen Xantia 1977 Citroen Ami 8 1996 Ford Escort 1989 Citroen BX 1997 Suzuki RF900 1988 Yamaha TDR250 1979 Honda CB400. 'I need less vehicles'
that to me sounds like a bad earth try cleaning the bradied earth strap
I would check for a bad battery connection or bad earth. Clean the battery terminals and the connections. Then fully tighten them. Check teh condition of the engine earth and you could even put a jump lead from the battery -ve to the engine to help.
slater
Club RR Member Number: 78
Sounds like a starter. Do you know if its pre engaged?
madmart
love is: valvebounce in top gear
has it got the original bl type terminals which press on and have a self tapper through them if so thats the most likly culprit there sh*t
all of the above!
I'd put starter as the last option, it sounds far more like battery is dud, connections loose or dirty, earth strap problem, main feed wire problem...
Rob
You know, for kids!
the click sounds like the solenoid - dead battery or dud earth again from me.
you have hit the starter with a hammer havent you !? always cured my starting problems.
with all the electrics going down... do you have a short somewhere..?. get yer multimeter out for some continuity testing, its great fun.
Rob
might be a silly question but is it manual or auto?
tigran
tis a manual.
Tbh the earth sounds about right - we only bodged the solenoid on with a (wrong) screw - I know this is what earths the solenoid to the body.
I'll get onto it with a pair of proper screws (and a hammer if it's being naughty)
Thanks gang!
