Jan 26, 2012 19:02:25 GMT
So I have a 1996 Zetec 1.25, and driving well over 500 miles a week... if converted to LPG would it be cheaper, or is it a simple case of get something else... I don't want to pay £1000 to have it done as its not worth it to me... suggestions please
Matt
Last Edit: Jan 27, 2012 19:43:16 GMT by mattmk1
Jan 26, 2012 19:32:12 GMT
Hi Matt,
I started writing out that it wouldn't be worth doing and started doing the numbers to prove it.. However, on paper it looks like your fuel savings would be around £100/month.
I still don't reckon it's entirely worthwhile though and I can' t imagine the Fiesta is that well suited to gas (size/space/weight etc.). Having run an LPG car, it was a bit of an inconvenience. If you do decide to go down that route, I'd be looking to buy something pre-converted.
Jan 26, 2012 19:50:57 GMT
that is a pretty fair comment, pre converted there seems to be plenty about, hmmm food for thought
Jan 26, 2012 20:39:33 GMT
10mpg
Club RR Member Number: 204
Jan 26, 2012 21:46:50 GMT
Zetec's are usually unsuitable for lpg due to their marginal valve seats, is the 1.25 the yamaha engine? you may be alright if so, if not beware!
I would rarely trust a read converted car TBH unless it was a known car.
With some flashlube in the mix and care it should be ok, but is it really worth it? 1.25s are meant to be frugal machines anyway...
Never found the 1.25 (yamaha) engine very good on fuel with motorway driving the gearing is setup for town driving always found polo's get better mpg.
Why not get deisel will be much better for mpg?
You'll also loose a bit of power aswell so will have to work the engine harder. Also if your mileage is near 100k you are going to be racking up the mileage on that engine.
Jan 27, 2012 10:53:30 GMT
If the car is sound have you considered buying a rotten diesel version and transplanting the engine ? Could be a lot cheaper than a LPG conversion plus option of running on veg oil Paul H
Jan 27, 2012 13:08:00 GMT
I would consider another car. For the cost of a conversion you could get a good Pug 306 HDi for that money. They are quite frugal and mega cheap to tax. Insurance is not too bad either. As the for Sigma engines and mileage they can take it. My Focus with 160k on the clock (1.6 V plate) still produced near enough stock power (when compared to others) on a rolling road day and that was with a slightly leaky exhaust too! As long as they see a regular service they are sturdy units .
Onne
Jan 27, 2012 13:11:01 GMT
Just as a note on the side, I fill up quite often with LPG (60 litres every 250 miles or so) and came across a Prius on LPG. Not that is just being tight...
1990 Mercedes W126 300SE 1997 Mercedes W140 S320L
Jan 27, 2012 15:10:48 GMT
Just as a note on the side, I fill up quite often with LPG (60 litres every 250 miles or so) and came across a Prius on LPG. Not that is just being tight... I went to a lecture by Leoni (used to be Lucas Rists) who make automotive wiring harnesses about the changes in electrical power requirments and the Prius came up in the discussion. We asked was there any reason why Toyota didn't use a diesel instead of a petrol and answer was the North American market was the original projected main area. Turns out at the design time N American tended to go for petrol vehicles leaving diesel engines for commercial vehicles and big SUV's. As such they tended to be more crude designs than the common rail etc we, and the rest of the world, get so the fuel is also not as refined. The diesel fuel that was widely available wasn't suitable for a high technology small capacity engine hence Toyota decided to go with a petrol lump. Things will now have now changed with small petrol engines now getting almost diesel economy so Toyota have stuck with petrol power for their hybrids. To me LPG hybrid is actually quite a sensible route if you are a "tree hugger". Personally I'm a petrol head and like carb'd V8's. Paul H
Jan 27, 2012 19:47:38 GMT
Diesel is definately an option, it worries me that people seem to suggest diesels require more regular servicing... I have no experience at all with a diesel car, as our household has always been full of petrol heads.
I also wonder whether the financial savings would work out worth while given current diesel vs petrol... bearing in mind I also need it to do well in traffic around town, as I drive... usually in heavy traffic 30 miles a day for work.
Jan 27, 2012 19:50:44 GMT
If the car is sound have you considered buying a rotten diesel version and transplanting the engine ? Could be a lot cheaper than a LPG conversion plus option of running on veg oil Paul H Intrigued by this... what is the current cost of vegetable oil, and how would the MPG compare? I understand Ben has ventured this way, but have never really looked into it any more.
Jan 27, 2012 20:33:33 GMT
If the car is sound have you considered buying a rotten diesel version and transplanting the engine ? Could be a lot cheaper than a LPG conversion plus option of running on veg oil Paul H Intrigued by this... what is the current cost of vegetable oil, and how would the MPG compare? I understand Ben has ventured this way, but have never really looked into it any more. If you shop around you can get veg oil for about £1 litre. Unfortunatley unless you have a twin tank system you need to mix it with ordinary diesel otherwise it's too thick - especially in cold weather. A diesel is going to be more economical than your current engine - which will be a little more thirsty if converted to LPG anyway. Paul H
Jan 27, 2012 20:35:23 GMT
I've been pondering a bit more.. Have you thought about a 1.5 isuzu engined Corsa? I say that rather than the 1.7 Astra/cav as it's in the lower tax bracket I've not been running very high percentages of veg. Maybe 30% or so. It'll have a play with higher percentages when the weather is a bit warmer. The only noticeable differences are the smell, the time taken to fill up and the funny looks you get when doing it in a supermarket carpark. Hardcore and Colonelk both run practically pure SVO thinned with Petrol and get on fine with it. Colon's is a 1.7 Isuzu td Cav, and Hardcore a VAG 1.9tdi in an Audi 80. Supermarket prices of SVO annoyingly seem to practically track the price of pump diesel but there are offers. Morrisons has some 3litre things on 2 for £6 at the moment, which is 90p a litre after you've borrowed your Dad's discount card To make it viable to do full time, you'd need to find a regular supplier (blag cash and carry access or whatever) but it certainly seems to be worthwhile doing. I carry a spare fuel filter just in case but haven't had to use it yet.
rodney
https://www.facebook.com/RD-vehicle-transport-and-recovery-services-525622614268010/
Jan 27, 2012 23:45:05 GMT
go turbo diesel and run on bio diesel , ive run loads and consumption was improoved too,.
facebook: rodney dean / rd transport
