redgt2
praise the lowered!
Jan 26, 2012 16:48:10 GMT
Hi can anyone tell me the id and od of copper brake pipe please....
I'm fitting a flush filler cap and it's mounting cut out from one bike petrol tank to another and need something to join the overflow pipes up....
I need a 6mm id connecting pipe....and looks like it will need a near 90 degree bend in it so thinking copper for it's malleableness....
Or any other ideas otherwise it will be stainless or mild steel I guess...prefer flexibility though
Cheers in advance
Red
v8ian
Jan 26, 2012 16:56:37 GMT
why not use 8mm nylon pneumatic pipe. that has a bore of 6mm,, infinitly flexible, and fuel proof
redgt2
praise the lowered!
Jan 26, 2012 17:52:39 GMT
Sounds like a very good option....thanks for that..
Is it the same as fuel pipe that I can pull off a carb at a breakers or get a metre off at a car accessory shop or is it better?
Last Edit: Jan 26, 2012 18:09:08 GMT by redgt2
v8ian
Jan 26, 2012 18:12:34 GMT
v8ian
Jan 26, 2012 18:15:06 GMT
Probably the same stuff, may be slightly thicker wall, if its stiff to put over the pipe, warm the end up with hot water, and perhaps a light smear of Vaseline in the hard pipe,
redgt2
praise the lowered!
Jan 26, 2012 19:13:54 GMT
Oo err sounds a bit rude...lol
But obviously the tighter the better so I don't get a permanent fuel leak....
Cheers Ian
