topcat
Jan 25, 2012 16:10:47 GMT
I have a set of mag wheels that came with my mini. I was going to polish the lips and raised bits but one has a little chunk missing from the lip. Given how light the wheels are I think they are a magnesium alloy.
Does anyone know if these can be welded easily or if a lumiweld kit could be used?
Jan 25, 2012 20:48:28 GMT
If they really are magnesium then you need to be wary of them. Magnesium is much more prone to age related problems and can even have hidden internal corrosion weakening the structure. Not saying they are useless necessarily, just that care is needed as techniques needed for checking them and refurbing them are more demanding than an ordinary aluminium alloy, are done by far fewer companies and doubtless cost more. But then a busted wheel can really spoil your day.... Welding wise, I'd say great care and not a little expertise would be needed as magnesium alloys can burn extremely enthusiatically. Early VW aircooled engines used magnesium casings and I once watched an split screen VW bus burn completely out (in Africa, no fire brigade) and once the engine and gearbox casing got going the fire went bright white. Nothing left after but crank, rods, piston rings, valves springs etc. www.weldingtipsandtricks.com/welding-magnesium.htmlCan be dangerous to use a grinder on it too apparently..... Nick
MrSpeedy
East Midlands
www.vintagediesels.co.uk
Jan 25, 2012 23:52:31 GMT
Magnesium is impossible and dangerous to weld unless you know what you're doing. IMO, a TIG set is mandatory.
topcat
Jan 29, 2012 17:41:02 GMT
I don't think these are pure mag, apparently they can almost disintegrate around bolt holes! I think I'm going to look for another wheel instead of repairing this one, thanks for your answers!
Jan 29, 2012 21:23:08 GMT
Better be safe than sorry with old magnesium wheels...
