You don't often get something for nothing
But in this case it seems different
Just logged on to DTA website and the latest Firmware for my S60 ECU has a variable speed sensor output ;D which is Mappable as well ;D
Its taken from the non driven wheelspeed sensor input, as used for launch control
What this means is ...........
My Power steering system has just got a wholeload easier ;D ;D ;D
A Corsa B or C Electric power column is not a huge job to fit as the Splines are the same as the Kadet and one of the column designs is adjustable for reach and rake as well which is nice
That means I can keep my Quick rack (2.2 turns lock to lock) Run Fatter tyres than I am currently for more grip, run more Neg-castor angle for more self centring on the steering and still be able to park it ;D ;D
All with (Mappable) speed sensitive powersteering ;D
Oh and that without shelling out the £250 or so for the little electrickery box that you normally need to fool the E-PAS ecu
Just needs a relayed ignition switched live, earth and the Trigger from the DTA ECU ;D
Happy........... you betcha ;D
