Right, if anyone wants to build a 4x4 camper this would be a good base, 5 door, 3 seat, fibreglass high roof as it is one of 17 wheelchair conversions.
It has a 3.5 V8 efi and auto box, 80k, runs and drives, been off the road for a couple of years and as such is deteriorating a bit. We'll never get round to doing anything with it unless we break it.
It has copious surface rust on the underside but it fundamentally solid, new brakes all round, new fuel pump. It had a ply floor in the back but we had to "remove" it to get to the fuel pump.
Boot floor is good, rear body mounts and crossmember (body) are bad, sills are ok, gutters don't look good but I'm too scared of what I'll find to prod it. That said, it' largely watertight.
It has a strange odour to it, somewhere between poo, mould, damp and public toilets but I'm sure that will go.
I can provide a replacement tail door and all other doors.
It has air conditioning which I believe works, all the electrics work except the remote locking, the tail lift was removed before we got it.
Offers around £695?
Would make a good camper, workshop, expedition vehicle, ice cream vam, burger van etc etc
It's not beyond saving but you'd need to be handy with the welding gear.
The motor is sweet as you like, a good RV8 alone must be worth something to someone, however, at this stage, if you want the engine you have to buy the whole car. So there. Ner.
I can supply any spare parts required apart from the bespoke bits, rear end door is a full height but modified from a standard unit and takes standard glass.
I'll try to find more pics, or talk to Alex on 01425 620626 office hours.
Offers around £695?
