B-8-D
down to one car!!
Sept 24, 2006 19:27:39 GMT
If the engine will actually fit getting it sat in the engine bay is normally the easy bit, some new mounts and a gearbox crossmember. The time consuming part is connecting everything and sorting out the ancilleries, such as a bigger radiator, wiring, plumbing, throttle, clutch, propshaft etc etc Then the exhaust is normally the biggest pain unless you are lucky and there is a manifold / system available off the shelf. We once did a Fiat into Minor, drive in drive out in 3 days. John yeah i remember doing a weekend swap when i drove my std chuvit in to the shed, pulled th motor and fitted a 2l pinto and box. i had the orig motor on the floor. and pinto in and starting on the key in 5 hours!! and i had to drive to a couple of friends for bits i forgot to get and fit the head clutch flywheel gearbox, head new cambelt, manifolds fuel pump etc etc.... the next few hours and on the sunday was spent doing the wiring tidy. fuel lines. plumbing the rad and mounting it etc clutch an throttle cables etc... by far the most tim consuming are the small bits. anyway the exhaust manifold and downpipe was by far the most (and only) difficult!! i did get to work late on the monday but i did make it... just!! the little bits and peices are by far the most time consuming in my experience.... si
mercmad
Sept 24, 2006 21:09:42 GMT
One swap I forgot too mention was a Mopar small block V8 into a Chysler Sigma,it BOLTS IN!!!.Chysler USA was building pickups in the early 80's which were basically Mitsubishis,using a Chrysler 904 trans,this meant that a V8 with a torque flite would fit on the same mounts,which it does.I have seen quite a few of the mitsubishi scorpians here with 360's etc bolted in,a few madna station wagons also have had the treatment.Only hold up is finding a rust free car.... Then there are these guys,Castle maine Rod shop who make adaptors for all sorts of swaps : "..... Datsun 1600,180B,200B box to Holden 6 AP 2 Datsun 240K,240C,240Z,280Z box to Holden 6 AP 3 Toyota Celica 1600 box to Holden 6 AP 4 Toyota RT104,2000 Celica box to Holden 6 AP 5 Chrysler Sigma 5sp box to Holden 6 AP 6 Plain Adapter Plate for Holden 6 AP 7 Toyota 4 & 5 sp box to Late Falcon 6 AP 8 Toyota 4 & 5 sp box to Early Falcon 6 AP 9 V8 Chev Turbo or P/G Transmission to 253-308 Holden AP 10 Datsun 1600,180B,200B engine to VW transaxle AP 11 Holden 6 engine to Toyota Dyna, Scout, Hiace AP 12 240k Datsun box to B2200 Mazda/Ford Diesel AP 13a Chev & Holden V8 engine to Nissan MQ Patrol AP 13b Holden V8-wide to Nissan MQ Patrol AP 14 GM Trimatic trans to Chev & Holden V8 AP 15 Toyota 5 speed box to Toyota Auto V8 engine AP 16 Rodeo/Jackaroo Diesel to Holden 6 AP 17 Rodeo/Jackaroo Petrol to Holden 6 AP 18 Nissan Urvan to Holden 6 AP 19 Mitsubishi Canter to Holden 6 AP 20 Toyota Supra 5 sp box to Mitsubishi 2.6 motor AP 21 Borg Warner T5 box to Ford V8 B/W bellhousing AP 22 Mazda T4100-Ford Trader 0811 to 253-308 Holden, Chev, Pontiac, Olds, Buick V8 AP 23 V8 Turbo 350, 400 & P/G trans to Holden 6 AP 24 Borg Warner T5 box to Holden & Chev V8 AP 25 Daihatsu to Holden 6 and V8 AP 26 Toyota 4 & 5 sp to 2 litre Ford kit ** AP 27 Range Rover to 253-308 Holden AP 28 Range Rover to Chev V8 AP 29 Ford Trader 0509- Mazda T3500 to Chev V6 & V8 AP 30 Holden 6 to CROWN Auto trans AP 31 Toyota 4 & 5 sp to Ford 1600 ** AP 32 Nissan Urvan petrol to Holden 6 (L.H.starter) AP 33 Mazda 2200 Ezy-loader to Holden 6 AP 34 GM Turbo & P/G trans to Ford 289-351 V8 AP 35 Nissan G60 to Late Falcon 6 kit AP 36 Nissan G60 to Chrysler Valiant Hemi 6 kit AP 37 Commodore V6 engine to Toyota Four Runner kit AP 38 GM Turbo & Powerglide trans to 49-54 Ford Side Valve AP 39 Three speed Landcruiser box to Ford 6 & V8 AP 40 Toyota 4 & 5 sp to Ford V6 English ** AP 41 Chev V8 to Jeep Cherokee auto AP 42 Borg WarnerT5 box to Holden 6, Chev & Holden V8 AP 43a Nissan C80 to Chev V8 AP 43b Nissan C80 to Holden V8 AP 44 GM Turbo & Powerglide auto to Hemi 6 AP 45 GM T5 to Holden 6 AP 46 GM T5 to Holden V8 AP 47 Chrysler 727/904 Auto to Hemi 6 AP 48 Chev V8 to Pontiac Turbo Adapter AP 49 Landcruiser to Falcon 6 kit AP 50 Toyota Supra to 1600, 2 litre & V6 English Ford ** AP 51 Holden V6 T700 auto to Holden 6 cylinder AP 52 Holden V6 T700 auto to Holden V8 & Chev AP 53a GM Turbo & Powerglide to P76 Leyland V8 AP 53b GM Turbo & Powerglide to Rover V8 AP 54 GM T5 (200mm input shaft length) to Muncie, Saginaw, T10 pattern AP 55 GM T5 Muncie pattern (200mm input shaft length) to Muncie, Saginaw, T10 pattern AP 56 Toploader Bellhousing to CJ6 Jeep 15mm adapter AP 57 Toploader Bellhousing to CJ6 Jeep 60mm adapter AP 58 Tremec 5 sp to Toploader pattern AP 60 Ford 289-351 left hand starter conversion for Auto’s AP 62 V6 Commodore T700 to Nissan 3 litre AP 63 Chrysler 727 auto to 392 Chrysler Hemi AP 64 1989 onwards Ford 0509-Mazda T3500 to Chev V8 AP 65 GM Turbo & P/G Trans to Nissan 3 Litre AP 67 1989 onwards Ford 0509-Mazda T3500 to Ford V8 AP 68 1989 onwards Ford 0509-Mazda T3500 to Ford 250 (pre EA). AP 69 1989 onwards Ford 0509-Mazda T3500 to Ford 250 (EA onwards). AP 70 1989 onwards Ford 0509-Mazda T3500 to Holden V8. AP 71 1989 onwards Ford 0509-Mazda T3500 to Chrysler V8 & Hemi 6. AP 72 Pre ‘89 Ford 0509-Mazda T3500 to Holden V8 AP 73 Pre ‘89 Ford 0509-Mazda T3500 to Ford V8 AP 74 Pre ‘89 Ford 0509-Mazda T3500 to Ford 250 (pre EA) AP 75 Pre ‘89 Ford 0509-Mazda T3500 to Ford 250 (EA onwards) AP 76 Pre ‘89 Ford 0509-Mazda T3500 to Chrysler V8 & Hemi 6. AP 77 V8 GM T5 to Ford B/W single rail AP 78 Toyota CROWN Auto to Holden 6 AP 79 Rangerover T/Flite Auto to Chev V6 & V8 AP 80 Late Ford ZF 5 sp to Ford 429-460 AP 81 GM Turbo & P/G Auto to Ford 429-460 AP 82 Rangerover ZF Auto to Chev V6 and V8 AP 83 GM Turbo & P/G Auto to Chrysler V8 Small Block AP 85 AB 130 International box to Chev & Holden V8 AP 86 Tremec 5 sp to GM Muncie, Saginaw, T10 Bellhousing AP 87 GM Turbo & P/G Auto to Ford 250 (EA onwards) AP 88 Holden Jackaroo Petrol & Diesel to Holden Commodore V6 AP 89 S/B Chev V8/C1600 Inter AP 90 Mazda E2700 to ford V8 & 6 AP 91 Toyota Dyna 3.5 Auto/S.B. Chev AP 92 Getrag 5 Sp - Holden V8 AP 93 GM Getrag/Ford Adapter AP 94 Mitsubishi/Dodge Canter - Holden 6 AP 95 Mitsubishi 3.3L to 250 Ford AP 96 GM Turbo & P/G Auto to Toyota 4 Litre Quad Cam V8 AP 97 Ford Windsor L/H Starter Adapter AP 98 Mazda E2700/Chev AP 99 Mazda E2700/Holden V8 AP 100 Mazda E2700/Chrysler AP 101 V8 Ford T5 to original EA 6 AP 102 GM Turbo & P/G Auto to Chrysler V8 Hemi 354-392 (as pictured) AP 103 EA 6cyl 3.9/4.0 Ford to H (petrol) Landcruiser Adapter (as pictured) AP 104 Landcruiser Auto/SB Chev V8 Adapter AP105A 250 Ford to H (petrol) Landcruiser Adapter AP 105B 250 Ford to 2H (diesel) Landcruiser Adapter AP 106 Jag T 400 to Chev Adapter AP 108 Chev Auto (T350/T400/T700/Powerglide) to EA 6cyl 3.9/4.0 Ford AP 109 Renault R30 Transaxle to Chev V8 AP 110 EA 6cyl 3.9/4.0 Ford to 2H (diesel) Landcruiser Adapter AP 111 V6 Holden to Jackaroo Hydraulic Clutch Adapter AP 112 V6 Holden to Chev Auto (T350/T400/T700/Powerglide) AP 113 V6 Holden to Nissan Navara left hand starters AP 114 V6 Holden T5 box to Chrysler V8, Hemi 6, Slant 6 AP 115 Nissan G60 to Ford EA-XG Engine AP 116 Ford 250 to Mazda T4100 Adapter AP 117 Buick V8 Nailhead to T400 Adapter Plate AP 118 Chev V8 to Nissan ED33 6 speed trans AP 119 GM T5 trans to all Aussie Bellhousing adapter plate AP 120 Oldsmobile to Chev T400 Adapter Plate AP 121 Toyota Supra To Series 6 Mazda Adapter AP 122 460 To 351 Trans Adapter Plate AP 123a H2 Diesel Landcruiser Auto To S/B Chev AP 123b H2 Diesel Landcruiser Auto To Holden V8 AP 124 Cadillac 331 Ci V8 To Chev Turbo 400 Automatic AP 125 Buick Nailhead To T400 AP 126 T5 To Chrysler Adapter Plate CRS1808 - 200mm Input AP 127 Mitsubishi Sigma To Steelcase Adapter AP 128 Holden Trimatic To Hold V6 Adapter Plate AP 129 T5 To Ford Single Rail & Toploader Bellhousing Adapter AP 130 Gen 3 Left Hand Starter Adapter
** Requires some additional specialist machining - inquire
Sept 25, 2006 7:45:40 GMT
Whats a Chrysler Sigma and whats a Mitsubishi Scoprion? Or a Madna?
Sept 25, 2006 8:52:21 GMT
I can see a 'Holden Trimatic', bit too close to 'Traumatic' that one.
Sept 25, 2006 10:22:32 GMT
Like the auto in the Triumph Acclaim...
