MrSpeedy
East Midlands
www.vintagediesels.co.uk
Jan 10, 2012 14:46:41 GMT
Again, not car parts, but invaluble tools to the avid 'fettler' amongst us. As with all of this type of gear I'm selling, these are top grade industrial quality of British manufacture. This is but a small sample of what I have. many different shapes and sizes, including some long reach (6" long shaft) and micro (3mm dia shaft) HSS not carbide, small ball rotary burr on 6mm shank £ 5 4 per 2 'Fir tree' shape TiN coated Carbide cutter 6mm shank. £ 5 4 ea (trade price on these is usually around £18) TiN coated solid carbide 60deg drill (centre drill) 6mm. £ 5 3ea (virtually scrap value!) Carbide 'Ball nose' parallel cutter 6mm shank. £ 5 ea 6 per 2 I have a huge selection, and any enquiries for bulk will be met with favourable prices If you have anything you particularly need, just ask, as I probably have them.
Last Edit: Feb 6, 2012 19:38:57 GMT by MrSpeedy
Jan 10, 2012 18:03:54 GMT
Hi there, I'm probably being a div, but what do you actually use these for? I know for cutting etc, but what? As thy have different heads?
I often use the ball nose carbide burrs to get into dips that an angle grinder disc can't reach.. Got a couple when I needed them a while back and now use them all the time!
MrSpeedy
East Midlands
Jan 12, 2012 11:08:05 GMT
Yes, very usefull tools for getting into awkward corners, or just for shaping metal/slotting holes etc
MrSpeedy
East Midlands
Jan 13, 2012 15:52:45 GMT
Bumple
MrSpeedy
East Midlands
Jan 16, 2012 10:09:20 GMT
Post weekend bump
MrSpeedy
East Midlands
Jan 21, 2012 12:19:24 GMT
Weekend bump
cavman
feeling inspired :)
Jan 21, 2012 13:33:37 GMT
yoinked this pic of the flea'bay, could you put a collection together that looks like this? and how much would they cost please? I can collect from Leics if that helps. many thanks. James
Last Edit: Jan 21, 2012 13:33:58 GMT by cavman
'78 Mk1 Cavalier Coupe - I wish I had a pound for every time someone told me "my dad used to have one of those"!!
Jan 21, 2012 15:00:14 GMT
Carbide 'Ball nose' parallel cutter 6mm shank. £5 ea
One of these posted please is Paypal OK?
MrSpeedy
East Midlands
Jan 21, 2012 19:07:19 GMT
Cavman- yh, I'm sure I can put summat like that together. I'll be back in the shop on Monday and sort summat out for you then ;-)
Hardassfunk- yh, paypal is fine. I'll pm you on monday when at pc :-)
I'm interested in a 'kit' like the picture above. PM me when you have something put together. Thank you please.
Jan 23, 2012 12:26:31 GMT
are these for use with a dremel or could you put them in a pillar drill and sort of "mill" parts?
'88 Toyota Supra Turbo
'88 Honda VFR 400 NC24
MrSpeedy
East Midlands
Jan 23, 2012 13:16:27 GMT
@ samwell
These are on a 6mm shank.
I do have another ad on here for smaller 'Dremel' bits which are on a 3mm shank
MrSpeedy
East Midlands
Jan 23, 2012 15:08:14 GMT
I have quite a selection and have tried to sort through them a little more. I have loads that are the same style but a different style, etc, so trying to catalogue them is nigh on impossible. However, I have come up with this; Let me know what you want and i'll get em off to you Any 5 for £20, posted.
Jan 23, 2012 20:36:33 GMT
Can i get 5 please (A B E F H ) Pm me how you want paid
Jan 23, 2012 20:47:31 GMT
you have a pm
bstardchild
Club RR Member Number: 71
These for steel or Alloy?
MrSpeedy
East Midlands
They're for both.
I've got some real coarse ones for Alloy as well tho. I'll look some out if you're interested?
MrSpeedy
East Midlands
Jan 25, 2012 17:05:24 GMT
All orders received and paid for have been dispatched this morning
bstardchild
They're for both. I've got some real coarse ones for Alloy as well tho. I'll look some out if you're interested? I am but I was looking for a both option - I tried a real coarse one once and it was frankly lethal!!!
