hello.
i have a twin m/cylinder pedal box and i am in the process of plumbing the front circuit.
this has a line from the master cylinder to a T-piece where it splits off to each caliper. the T-piece is in the drivers side wheel arch.
This means the line from the master cylinder to the T-piece and the T piece to the drivers side caliper are quite short but the line from the T-piece to the passengers caliper is quite a bit longer as this has to go all the way across the car.
Is this OK? or does the T-piece need to be in the middle distance wise?
thanks very much
thanks very much
