Just after it was running, I slipped with the spanners.... Whoops And whilst waiting on shiny bits, the old 5-piece rivetted and glued roofskin was made into a lighter, welded single piece effort. Much cursing and hammering was heard in the process. Sounded easier than it was, ripples all over the place to start with. Bonnet got finished off and the upper roof-intake got reworked too: Then the roundy-roundy bits went back in: And the uppy-downy bits: And her little red hat back on: And then I used some of my terrible Paint skills to try out a few paintscheme/louver options, this maybe I think:
Last Edit: May 7, 2016 20:33:13 GMT by phillipm
alecf
I've just got back from Tong, not many there to be honest, think a few have gone over to BCCC. Mates there spannering for another mate. They shut the course for a while due to a fire
Yeah, I heard, Jason's over there codriving for Rob Bool, sounds like the Fouquet was winning?
Just like everything else on the car, we decided to go nice and discrete with the louvers.....and promptly made them massive and lots of 'em.
As you can see, engine is back in and running again, plenty of finishing touches going on, just waiting on some CV joints and it can go for a run, made some new adaptors to the CV's from the transaxle as the old ones were pretty tired, welder solves all: Anyway, TL:DR, it runs, sorted all the leaks and teething issues you get on builds like this, waiting on CV's so it can move - then we'll sort all the leaks and teething issues we get from that, then off to dyno-land for mapping. Then maybe some paint after a few testing sessions.
Last Edit: May 7, 2016 21:44:41 GMT by phillipm
Could you run it naked?
It looks super mean!
Koos
Actually there's one club we could - but given all the hot bits, spinning belts and that it'd have terrible cooling airflow, I think we'll have to stick with the rear bonnet
Mocking up the rear wing, cutting the cardboard rib templates isn't a fun job though!
May 10, 2016 22:50:29 GMT
Now we've evolved into PAD, it's almost structural. *Needs more duct tape.
May 11, 2016 21:49:44 GMT
Having lots of fun hand cutting all these wing ribs, honest (and each rib is made of 4 or 5 separate laminated pieces): Not even 1/4 way through yet :/
May 11, 2016 23:05:46 GMT
So do I and who knows, one day we may actually see it race! That Paint rendition is seriously mean.
May 11, 2016 23:11:19 GMT
You might indeed see it moving again - one day....in a galaxy far, far away...
"Use the Force!" "It's not working Master!" "Then get a bigger hammer and use more Force!"
Last Edit: May 11, 2016 23:12:23 GMT by phillipm
May 12, 2016 12:46:13 GMT
Do you want a Lola Group C race car wing for cheaps?
Koos
May 12, 2016 15:44:00 GMT
Maybe, depends what you call cheap Although I guess it's a relatively low downforce and high Reynolds design?
May 12, 2016 18:08:55 GMT
What's that in English please? :-P
Got any interesting beetle bits left over?
Last Edit: May 12, 2016 18:10:32 GMT by mdh
Koos
May 12, 2016 18:55:16 GMT
Relates to the size and speed the wing is designed to work at - basically some wings work well at low speeds, poor at high speeds, and vice versa.
Got a few, the old 3x3 rear arms, shafts, brakes, etc, etc, same with the 5 star front aluminium wilwood hubs + disc - plenty of old Bilstein dampers but I think half of them are pretty tired.
May 12, 2016 20:50:06 GMT
Good news, the CV joints are here! Bad news, they're the undercut 'race' ones with undersized CV balls that we don't want, as they're curse word for wear and distort where the bolt heads are undercut. So yes, more waiting....
Last Edit: May 12, 2016 20:50:28 GMT by phillipm
More wing pictures time - finally got the first skeleton up to full width - need a thin sheath of balsa in certain spots just to give it some shape in order to skin it with either fabric or fibreglass to give it a structural skin, the wooden spars will get replaced with aluminium tube when it arrives, and it needs some carbon + epoxy reinforcements to go in on the trailing edge to stiffen/strengthen it, but at least it's getting closer - just another 3 to go...
PhoenixCapri
West Midlands
Club RR Member Number: 91
May 18, 2016 14:20:59 GMT
Well this is rather epic, how the heck did I miss this thread!
Nice wing, bet that's light
