Jul 23, 2015 20:35:34 GMT
Been a while since updates, but had a lot of health and family health issues, currently nursing a broken arm myself too just to top it off! Anyway finished off some last bits of dashboard wiring(few extra's been added, launch control settings, etc), and tidied the wiring behind it into neat runs, switched idiot lights out for LED's (which then required ripping them to bits and trying to add diodes and ballast resistors in the case of the alternator charging light....good fun trying to solder them in a space about 8mm x 4mm.....lots of swearing, some burnt fingers. Anyway, kettle went on, coffee came out, shiny lights: Little bit more to tidy up on the back, and the green connector for the passenger controls needs a hole cutting to mount it to, but pretty much done: As promised, new front bonnet, ignore the steel box section, it was just there to hold the front square whilst welding as it's fairly thin aluminium, it's on hinges now and will get a gas ram lifter fitted to secure it, much easier to work on if you break down away from the service area then. And new floorpan is on, new bulkhead, seat mounts, pedals, etc: Whilst having a coffee we decided to create even more work for ourselves, and decided to change the front wheels to some nice light Mitsubishi alloys we'd found, since it's on alloys at the rear now - unfortunately what we hoped would be a simple spacer job turned out to require a complete new hub, otherwise the car would have been 6 inches wider up front - anyway, we decided that wasn't much more work than making new front wheels anyway (old ones were pretty tired by now), so 2 lumps of ally billet later.... The bearing cap is rather large but it goes through the wheel centre and acts as the cap to stop dirt sitting in the void (plastic caps don't last long), and being taper help centre the wheel for easier/faster changes: Bells required to mount the brake discs to, due to the stud pattern for the alloys requiring much more clearance at the rear to get the studs in: ....annnnnd then we sat back, drank more coffee, decided the postage stamp sized front pads might struggle with the heat with another 100bhp, and decided to swap to some old dynalite 4-pots we'd been given, broken, but nothing we can't fix But they need bigger discs to suit the pad shape. So... Could have just made the discs to start with without bells, doh!
Sept 28, 2015 19:22:19 GMT
I forgot to list THE MOST VITAL, GROUNDBREAKING PERFORMANCE MOD EVER! Knocks 10 seconds off the Zero-to-StrongEnoughToTarnishTheSpoon time for most good* teabags: *Yorkshire tea, obviously Anyway, hub got anodised, fitted, and the new calipers mounted after fabricating a new bracket: Engine loom got modified for a better main connector that has removable pins and is rated to work under 6ft of water: Thousands of miles and plenty of trophies to it's name, but that abused old Peugeot 106 steering wheel is finally retiring from it's life of misery and pain (Ed's taking around the back and having it shot*). Of course, that means an adaptor is required for the new one. The remains of my 306 got butchered for a column spline to use for spinning a new adaptor up in the lathe - thankfully it hasn't been disconnected to sell yet! Lightening scallops courtesy of a Mr A.Grinder... Due to having to TIG the old centre spline in it's all in steel, so no shiny anodised ally things today for you all. Terrible, I know - I'm sorry. I think that's -5bhp for lack of anodising and -8bhp for not being able to say 'Billet Ally!' when talking about it. (*KIDS! I'm joking, the wheel has gone to a home for retired steering wheels, it's getting leather food every day and frollicking in fields with other wheels, it's in a caring, happy place - and definately hasn't been violently butchered by an angle grinder wielding maniac requiring the steel spline out of the centre.) A barn door appeared: And the spars are being 3d printed at the moment: Roughly what it should end up like when it gets made and mounted:
Sept 28, 2015 19:42:35 GMT
Ah, a welcome rise to the top of my bookmarks.
Nice update. When's the next outing?
Sept 28, 2015 19:55:53 GMT
Just waiting on some parts coming back from plating, and some fuel hoses from a local hydraulic place, but barring a few odds and ends it's going back together now to be fired up. We need to clean and check the engine over this weekend - remove all the blanking plates we fitted to stop anything getting in while working on the car and alter some of the timing gear - then hopefully get it outside next week.
Oct 13, 2015 21:18:10 GMT
1 step forwards and 96 steps back today with a load more issues discovered whilst reassembling - but working through them, and the front is finally together on shiny new alloys. We've even got a Christmas theme going as it looks like someone based the wheel/centre cap design on Rudolf...
Oct 25, 2015 16:58:42 GMT
Fantastic read! Love the thing. I wish my friends were more like you guys. Not everyone can build and use something like what you've got. SUPER Cool.
Dem sure is some puuurty brakes mistah!
Is the front beam home made?
Koos
Dem sure is some puuurty brakes mistah! They surely are! But a question from an old thicky. Why are the 'discs' shaped like that? I understand vented, but as these are solid, is the shape for cooling/heating/water shedding/look pretty? Please enlighten me. Thank you.
Dem sure is some puuurty brakes mistah! Is the front beam home made? Yes, T45 tube, although the centre was the original VW part but with adjusters welded in, as were the old shock towers, albeit much modified - the adjusters are gone now though, weight saving The discs are shaped like that as they help shed water and debris from the surface, and the extra working edges also mean harder/higher temperature pads can be used without sacrificing low-temperature bite. Also leads to a lighter disc for the same pad area and brake torque - I used to run some vented version on my 306 daily too, there's an old thread on here somewhere, meant I could use high torque endurance race pads without worrying about warming them up on a cold winter morning: Anyway, I need to update this thread a bit, it's running now
Last Edit: May 6, 2016 10:33:56 GMT by phillipm
Thanks for that and yes, you do need to update!
Right, trying to remember what was after that, but I think it was the bodywork, so, to take the heat away from the engine bay around that large manifold, the lower panels became louverly (see what I did there, eh? Good wasn't it?): Skidpans went on too - 6mm thick aluminium plate for the transmission - which goes forward under the beam tube/seats and is overlapped by the main floor for a while so it's even thicker there. The transmission plate also overlaps the engine plate when that is fitted so there's no leading edges anywhere to dig in - making the underbody armour half an inch thick in some sections - it still takes a beating mind, but it stiffens the overlap laterally to stop it bending upwards too. The front beam and front section of the floor gets it's own piece of 6mm plate too which wraps up around the front beam and up a few inches to prevent the beam digging in on a nose-hard landing/drainage ditch crossing. Unfortunately it doesn't look this shiny for long! You'll have to excuse the rear of the floor, one of the helpers thought a hammer was a good substitute* for a sheet metal folder.... [small]*It is, but not how he uses it! [/small] Couldn't afford a CAT scan to check the discs for flaws, so went for the cheaper alternative: He said they were a bit Ruff. Rerouting some piping before Christmas, along with some other changes the eagle eyed might notice - basically the hoses were a little close to hot spots for comfort, even with heat shielding, mainly because they'd been made few mm long by the supplier but with such short, wide hoses getting rid of the extra length meant routing at quite an angle into some of the fittings, and it also meant the dry sump belt was difficult to access - not something you want in the field! Anyway, chances are the hoses would have been fine but after this amount of time an oil fire is not the way you wish to discover that they weren't... That knocked on to shifting a few bits and pieces (exhaust relocated by removing the right rear frame support tube, and shuffling of the oil filter mainly - although then I decided I didn't like it anyway, so then it got moved again to completely under the engine now there's room due to the exhaust shift) and then it meant remaking panels that were already done: Welded up awaiting the top rolling over the tube: This was probably posted after finding some decent whisky in the back of a cupboard: And some louverly (Yeah, I did it again, sue me) new vents.
And it was a long run to get here, but just before christmas, this happened...
What a teaser... Mental build anyway, I was thinking earlier today that I do need a sandrail and this thread convinces me even more.... My father killed numerous splits, ovals and T1 transporters in his youth by building sandrails, of course never anything close to this one but it is always fun to bring up in VW crowds today.
194? Willys Jeep MB 1965 Volvo 544 Special 1968 Opel Rekord 1975 Opel Kadett Estate 1985 Mercedes-Benz 230E 1985 Datsun 720 King Cab 4x4 diesel 1997 Volvo S70 2.5SE (ex. "Volvo544special65" - changed to more reader friendly username. )
alecf
Very nice engineering in this mate.
So I'm not the only nutter on here who finds these things fun and spends hours upon hours building them.
Nope, afraid not.
I think you're supposed to race them at some point too.
And because I'm not completely cruel - one with it actually running, albeit with a whistling airleak that seems to be the only thing the phone mic picks up on:
Last Edit: May 7, 2016 18:25:20 GMT by phillipm
alecf
Nope, afraid not. I think you're supposed to race them at some point too.[/quoteo] Don't rub it in lol. Missed baden Hall with s&s last weekend. Popped over to marshal but it doesn't scratch the itch. Missing tong this weekend. Which now means I won't be doing the first round of the hillrally championship at the end of may. The Welsh baja Gutted to say the least.
alecf
Loving the rotty trying to catch the fumes. Mine was just as daft.
I've just got back from Tong, not many there to be honest, think a few have gone over to BCCC.
