Dec 17, 2011 19:47:36 GMT
I'm taking my car in for an MOT next, need it on the road quicker than planned.
Is a cracked windscreen where the tax disc is so outside of "zone a" around 6inches an MOT failure?
The handbrake works but has alot of play, failure?
Cheers
froggy
Dec 17, 2011 20:02:39 GMT
yes and maybe
Dec 17, 2011 20:49:44 GMT
maybe and maybe - is the crack inside or outside of the swept area of the wipers?
Dec 17, 2011 20:54:41 GMT
if its just inside the wipers, how do ya stand on fitting smaller wipers?
I'm not curse word, i just fell off my shoes
bl1300
Dec 17, 2011 21:08:39 GMT
what do you mean by the handbrake has a lot of play but works? Does the lever reach the end of its travel but still hold the car, my car was like that last year and it was a fail. Simple solution though shortened the handbrake cable
Current fleet.
Dec 17, 2011 21:18:31 GMT
if its just inside the wipers, how do ya stand on fitting smaller wipers? Test as presented - pass and advise On the handbrake, if it has no reserve travel (I.E. it is holding on the last notch) then it is a fail. If it has side play in the lever that is so excessive that you can release the brake by pushing it sideways, it is a fail. In all other cases (assuming minimum efficiency is met) pass and advise.
froggy
Dec 17, 2011 22:38:04 GMT
If it's a couple of inches you should get away with it but if there are marks to show the original swept area you might get a fail for not effectively clearing the screen . I had this a few years back with a smartarse putting a 13" blade on a transit to try and get around having a big crack in the screen after I failed it a couple of weeks earlier
Cheers lads, looks like I'll be needing a new windscreen and the handbrake sorting.
