Mar 20, 2014 12:12:27 GMT
And in the same vein of making things more comfy I finally got a decent hatch spring cover, painted it black and fitted it. Hatch sprig cover. by quickrack, on Flickr And I got some reasonable doorcards which I repaired and fitted instead of the alloy ones I had cos they acted like cymbals Much nicer now. 190320145549 by quickrack, on Flickr Hatch sprig cover. by quickrack, on Flickr 190320145555 by quickrack, on Flickr I also fitted a really early heater cover after finally connecting up the heating ducts. 190320145553 by quickrack, on Flickr Here's how the dash looks now. 190320145552 by quickrack, on Flickr I have borrowed a 3 spoke, flat spoke type, steering wheel to try out but the boss is so deep I don't see it being any different.... photos when I take them in the morning. However a lot of the effort to make it quieter was twarted by the 2 piece propshaft I'd fitted. It was squealing and knocking and rattling and horrible. A mate though, in need of a spare bit or two, happened to have this 190320145557 by quickrack, on Flickr A professionally converted sierra one Will get that in tomorrow morning. Cant wait to try it. Will also be cutting snd bending and welding the gearlever to TOTALLY clear the handbrake as its a right pain hitting yer hand instead of 2nd gear. Opinions etc welcome. keeps the motivation up!
Last Edit: Mar 20, 2014 12:26:32 GMT by Deleted
Mar 20, 2014 12:57:19 GMT
good work as always mate,those seats do look comfy.good find with the early heater cover,i have been looking for a decent one for some time.i moved my handbrake back 2" to clear the gearlever on mine but a quickshift helps with clearance too.keep up the good work.
too many toys..too little time...and usually too little money.
good work as always mate,those seats do look comfy.good find with the early heater cover,i have been looking for a decent one for some time.i moved my handbrake back 2" to clear the gearlever on mine but a quickshift helps with clearance too.keep up the good work. Never thought of moving the handbrake... I am going to cut the lever on the outside edge of the bend, straighten it out some (enough to clear my finger/handbrake/pain interface ) and re-weld it.. Hopefully I will get a test drive in my improved escort tomorrow. Or I get to remove the gearbox and try to find a replacement..... Wish me luck!!
Great looking Escort you´ve got there mate. Keep up the good work.
Mar 21, 2014 10:21:21 GMT
Great stuff, love the seats and that Springalex wheel. Wanted one of those in my Escort so badly i had to shorten the steering column four inches (MK2 Column in a MK4 shell) Keep up the good work
Mar 21, 2014 16:49:20 GMT
Great stuff, love the seats and that Springalex wheel. Wanted one of those in my Escort so badly i had to shorten the steering column four inches (MK2 Column in a MK4 shell) Keep up the good work Cheers. I can relate to that. I have a spare one hanging in the garage. Just in case like.
Had to take my Springalex off cos I couldn't get my fat belly between it and the Recaro
Mar 23, 2014 10:45:23 GMT
Had to take my Springalex off cos I couldn't get my fat belly between it and the Recaro I am on a diet for the same reason. Have cut out bread,pasta, rice,potatoes and take a wee walk most days. Lost 9lbs in 18days so far. Also means my escort is now faster
Apr 21, 2014 15:40:24 GMT
Well I had her out for a couple of spins in this nice spell of weather. But what started as a wee tremble under braking quickly became a shake. Inner TCA bushes I suspect. But worse was a knock from the left rear. Looks like my new exhaust was too close to the shock to start with and moved closer. Enough to melt the cover. And I think, the seal. Best case will be a loose bolt but I think its doogened. Will get under it tomorrow. Cant face it now.
Apr 26, 2014 16:32:52 GMT
Apr 26, 2014 19:14:15 GMT
That looks like a cracking garage
v8jim
Apr 26, 2014 20:13:20 GMT
Turn your exhaust clamp around to gain a few precious mm What orange is this? I know someone who's having a mk2 painted signal orange and I was expecting is to be really bright like yours which is awesome but it's a bit of a let down
Max sig pic size: 80px
Apr 26, 2014 22:39:12 GMT
Turn your exhaust clamp around to gain a few precious mm What orange is this? I know someone who's having a mk2 painted signal orange and I was expecting is to be really bright like yours which is awesome but it's a bit of a let down Yeah but then it hits the gearbox mounts I'll sort something out. Eventually. The colour is Ford Focus ST Electric Effect Orange.
Work has begun. I have minimal strenght in my right hand (thank you oesteoarthrosis)so I can only do so much at a time. Its on axle stands and I have the inner tca bush replaced on drivers side. Before and after bushes Inner TCA bushes by quickrack, on Flickr Also have everything loosened on pass. side. Whole strut coming out as I need to fit a new top mount. Strut top. by quickrack, on Flickr Also rotated the problem exhaust clamp. Now some advise needed please. I was thinking of lifting the exhaust almost all the way to the floor. Doing away with the rubber hangers. And adding a flexible join to take engine movement. This will free up another 1.5 or so inches. What do you think?
v8jim
When I make exhausts I cut the hangers off of scrap exhausts (I work in a garage) then you can use the proper rubbers that fit tightly,weld the chassis hanger up a high as possible so the rubber only just fits between it and the floor then the exhaust one level with the bottom of the pipe that way the exhaust is as close to the floor as possible and tight on the rubbers so it won't knock I apologise now for the poor sketch I hope that made seance
It does. That alone would give me load of clearance. I remade my hangers already to raise it some, so re redoing them is no bother. Thanks.
Be carefull , this lowering lark is addictive !! Before you know it you will be cutting exhaust tunnels in your floor pan!
very nice mate - keep up the good work
You've got loads of clearance Love the colour, and always preferred the estate version of these, top stuff
Love the colour, and always preferred the estate version of these, top stuff Ditto. I didn't realise it was that low until I saw the coke can comparison photo.
