Dec 14, 2011 21:19:16 GMT
I have asked this question in lots of places and had no reply, so thought I'd ask here.
Does anybody know the distance between the Track control arm inner points on a Capri crossmember?..
Cheers
Paul
Dec 14, 2011 21:50:29 GMT
Do you mean the lower arm mounts? (the other end of the bit with the balljoint - the track control arm mounts through the middle of this rather than onto the xmember) If so I can find out tomorrow.
Dec 14, 2011 22:09:24 GMT
Hi M8, I'm after where the TCA mount onto the crossmember... If you've got a Capri handy to measure, could you measure the distance across the strut tops aswell?.. Below is a Mk2 Escort Crossmember with the 591mm measurement Cheers Paul
Last Edit: Dec 14, 2011 22:14:12 GMT by ludsonline
Dec 14, 2011 23:14:47 GMT
Yeah, that's what i thought you meant. I'll take a tape measure to the spares pile in the morning and report back.
Dec 15, 2011 12:05:20 GMT
Yeah, that's what I thought you meant. I'll take a tape measure to the spares pile in the morning and report back. Any news M8?..
Dec 15, 2011 16:02:38 GMT
yup, 680mm between the bolt centres
Dec 15, 2011 18:41:42 GMT
Cheers m8 ..
Well my car measures 650mm, so I'm going to have to take the boots off the rack & measure that. It could explain the weird handling at 60 odd mph...
