prey
might very well be a stupid question but....
what's the implications of machining a wheel bolt? either nipping a bit off the length with a grinder or what i'm pondering which is sticking some 'bubble' taper bolts in a lathe and cutting a 60 taper on them?
gracias por favor.
can't see why not can you not get the right bolts though?
Seth
Well, they weren't made by magic so probably saw a lathe at some point in the past.... Not likely to be a problem as long as you machine them right and don't take too much metal off and weaken them. If I could buy nice new ones off the shelf for my application I'd probably to that myself though.
30psi
I'd say its ok as long as you don't get too much heat in them
1962 Ford Thunderbird 6.4L
1981 Datsun Bluebird SSS CA18DET
1981 Datsun Bluebird SSS SR20DE
Taken a bit off many a bolt for clearance before. I would tend to put them in a vice and go through with a cutting disc though - less heat generated.
prey
just as a have a couple of sets of longer bubble taper bolts which i will never use and a need for some 60 tapered ones - so a bit of time and i can reuse rather than buying a new set. cheers for the answers.
rtlkyuubi
Low and Slow
Dec 10, 2011 15:54:09 GMT
heat will do nothing to them. if we get a truck in at work that needs the brakes doing but the wheel nuts wont budge, we heat them till just cherry red and then they come off if the inch air gun
Last Edit: Dec 10, 2011 15:54:43 GMT by rtlkyuubi
