morrx
G'day A few pics of my Minor 1000, now just a little different from most. As I bought it 3 years ago. And a couple of it now Mister Morris claimed 28kw and Mister Mazda claimed 120kw, it is now a little faster even with the air con on. Cheers Graham
Last Edit: Nov 11, 2012 23:33:56 GMT by morrx
1959 MORRIS MINOR 2 DOOR WITH MAZDA injected, 6 port, 13B
Did you have to cut the bulkhead about to fit it?
*n
Welcome across, not too many cars which can claim 4x their original power!
Remade In Australia thereimaginarium.com.au
morrx
G'day No cutting of the bulk head. The support arms had the lip on the inside removed were then seam welded and then had a strip of angle welded on. The front cross member was removed and replaced later so it fitted around the changes. New engine mounts were made and the engine trial fitted. There seemed to be plenty of room at this stage. By the way the car is called MORRX as it is a combination of a MORris and an RX7, engine/ gearbox series 5 6 port injected 13B/ 4 speed auto, diff series 2 3.9 with disk brakes. Cheers Graham
Last Edit: Dec 7, 2011 12:25:06 GMT by morrx
very nice!!! love minors and love RX7's good combo mate!!!
dtvracing
On the diff....
a moggy is hard to beat, my first car really like it, great job mate
I love these, they have the "hooligan" look about them straight from the factory!
luckygti
I need to try harder!
Very cool, welcome along
morrx
G'day Thank you for the positive comments. A couple of inside shots. Cheers Graham
morrx
Dec 27, 2011 10:04:11 GMT
G'day Tomorrow is the third anniversary of my buying what has become MORRX. It has been on the road for a bit over a year now and is slowly getting the way I want it. As it was when I bought it Now Cheers Graham
Dec 27, 2011 14:00:29 GMT
...Yes. Love that! Very much a sleeper.
tomgt
Dec 27, 2011 21:52:23 GMT
Awesome, must have been hell of a job carrying out that conversion!!
On the hunt for a taxed a tested retro ride, hatch or coupe. Under 1500 if possible
What have you got?!
Life isn't the same without a car....
morrx
G'day HAPPY NEW YEAR I have finally changed the passengers glove box lid to match the drivers side, now all I have to do is have it repainted and sort out the switches and the dash will be finished. The problem ,which caused the delay, was that its hinges were on the bottom requiring that it be bolted/screwed on the under side of the dash unfortunately the air con was in the way. A mate, at home, came up with a solution to make up new hinges attaching to the old mounting points then stepping down to the bottom of the door with the hinge there, it works a treat. He dose not even have a Morrie, just a ww2 Ford Jeep, Bullet Mustang and an Austin Healey 100/4. I finally had his idea turned into reality at Axe Welding/Giddy up Horse floats in Drysdale a very helpful man who was able to re use, with some modification, the bracket/hinges that were on the door. He only has a V8 FE Holden and is building a 40's Chev Coup Ute with a 350 but no Morrie. It is wonderful how helpful some non Morrie owners can be. Cheers Graham
morrx
G'day Morrx went to the inaugaral Drysdale classic car show today and met up with the Geelong Morrie Club. There was a good turn out of a large verity of cars, as they said in the add from MG's to Mussel Cars. But I liked this the second best there. Cheers Graham
Seth
That's a really good looking engine conversion. And with ari con too!
morrx
G'day Before and Now A bit different from original. I got in the back seat to take both picture, it was a lot easier with the original seats. Cheers Graham
Jan 20, 2012 10:37:40 GMT
One of the best things to do to a minor ;D other than turning them into washing machines imo
Jan 21, 2012 13:28:46 GMT
One of the best things to do to a minor ;D other than turning them into washing machines imo Try reading the M.O. 2) If you haven't got something constructive to say, say nothing Sure this is stifling your freedom of expression, however I'm not interested in cars you don't like, I'm interested in cars you do. Conducting oneself in a positive manner will result in positivity. Read more: retrorides.proboards.com/index.cgi?board=general&action=display&thread=45829#ixzz1k6CYH4g1
Jan 21, 2012 17:51:51 GMT
Do like this. Especially the addition of creature comforts like aircon for the warmer days- though the speedo I see goes to 125.. how many times you've had it wound round then?! ;D
I love the look of "modernized" without losing the original charm of the car. Nice work.
--Phil
morrx
G'day Morrx went to the Queenscliff rod run display today, we parked in the non entrant area, surrounded by Thunderbirds, A Road runner and a very old Chev pickup. Morrx was not the only Minor there , this one unfortunately had its bonnet blown off, by a strong gust of wind, just after I got there. Some of you may know the Ute it has been around for a while, 3.8 V6 Commodore engine with a 2" or 3" roof chop. A rather neat looking Morris 8 or 10 I can not remember. And even an Austin And there was a few hundred Fords, Chevs etc Cheers Graham
Hiya, Glad you made it over here. I love seeing more rotary conversions and cars like yours may well get more people into the idea of using these great, cheap to buy and easy to fit little engines.
Why did you use an auto? Was it because thats the way your engine setup came and you stuck with it or did you want to go auto?
