Dez
Club RR Member Number: 34
Nov 26, 2011 15:54:55 GMT
it came on a horrible, horrible trike that was seemingly mostly cortina based (english axle, 2l autoboxed pinto, cortina gauges and switches). so i assumed mk3/4/5 'tina, but i don't think the mounting plate should be at an angle, should it? i then thought transit, but apparently the front line should be bigger on them and they're both the same size here(m10). any help greatfully received!
Nov 26, 2011 16:04:17 GMT
Pretty sure that's a sierra one.
dan91
Nov 26, 2011 16:41:26 GMT
Looks Sierra.. Looks identical to the one we used for building a kit car, and that's from a pinto Sierra.
Dez
Nov 26, 2011 16:49:52 GMT
I guess it could be sierra. I just cant identify which sierra! its different to another one I have that is labelled as sierra, but ive just looked on ebay and so far have come across 6 different types looks like its one of those parts they liked to change regularly for no particular reason. it looks as thought the canted mounting flange location is specifically sierra though, cheers guys either way, after a quick rebuild it should be perfectly suited to the 100e build I'm doing for the missus, which saves a few quid!
Last Edit: Nov 26, 2011 16:53:39 GMT by Dez
Nov 26, 2011 17:02:08 GMT
Went outside and took a photo - any help ('90 ghia twincam) It's similar, but not the same as the one you have - the pipe outlets are in different places. I can well believe there are 6 types too
Nov 26, 2011 17:41:32 GMT
smiley transit?
Nov 26, 2011 17:47:03 GMT
not too sure but that looks remarkably like what is on my 79 transit mk2 ill get pic when I'm at work monday (out of curiosity)
Nov 26, 2011 21:00:58 GMT
It looks very much like the one on my 1980 MK2 Escort 1.6 X-flow.The only diference is the lines exit on the other side. The mounting is on an angle so the fluid marker lines sit parallel to the ground. Mine has a servo so the master sits at the end of the servo tower.
sierra or poss mk3 escort servo type.
due to the 3 pipes & diagonal mounting holes more likely sierra.
def not transit,capri/escort 2, cortina or granada.
theres more to life than mpg & to much power is just enough.
Nov 30, 2011 22:00:06 GMT
Think it might well be a Escort Mk2 one
Dave
Dez
Nov 30, 2011 23:06:41 GMT
as noted above its deffo not transit, mk2 escort, cortina, etc. the mounting flange rotation is wrong. with the help on here ive narrowed it down to sierra, and its seems its probably the type fitted to boggo late non-abs sierras and p100s.
It could be a master cylinder from one car joined to a reservoir from another. The actual cylinder looks like a mk4 escort one
bortaf
Nuts was just gonna say checked my p100 today and appart from the lid (should be yellow) it's identical BUT without the colourd band you'll have to strip it and measure the bore. For referance in the future Tie Wrap Color Bore Size Black 15.9mm (5/8") Blue 17.8mm (0.70") Green 19.1mm (3/4") Orange 20.6mm (13/16") Red 22.2mm (7/8") White 23.8mm (15/16") Yellow 25.4mm (1.0")
Last Edit: Dec 1, 2011 22:26:46 GMT by bortaf
R.I.P photobucket
