mdw
Nov 15, 2011 22:00:23 GMT
I've just got a towing dolly and i need to get some brake parts for it. THe problem is i have no idea on what make/model.
Can anyone recommend a good (cheap) supplier of brake parts for trailers?
Also how can identify what i need i.e. part numbers where should i be looking?
Thanks
1989 VW Caddy 1993 BMW 316/2.5 Touring 1985 BMW 316 (e30) 1984 BMW 316 (e21) 1992 VW Passat 1984 Porsche 924 - SOLD 1985 Volvo 340 GL - disfigured Now cubed 1990 BMW 318i - Sold 1989 BMW 535i SE - executive express SOLD
purplevanman
Way too orangey for crows
Nov 16, 2011 18:54:16 GMT
can you get some pics up? I identified both my braked trailers via a photo of the shoes and then a trawl through ebay looking at their pics 1 turned out to be ancient, even down to BSF threads!!! Still got ID though ;D
Nov 16, 2011 19:01:15 GMT
There's lots of different ones so pics would definitely help. What stud pattern is it? Are the brakes operated by proper bowden cables and how are they adjusted?
mdw
Nov 16, 2011 22:27:07 GMT
Last Edit: Nov 16, 2011 22:30:02 GMT by mdw
purplevanman
Nov 16, 2011 23:09:31 GMT
Just had a quick look but can't see anything Are the backplates on 4 bolts? Change the whole thing if you can't ID them?
mdw
Nov 16, 2011 23:34:03 GMT
backplate looks as though its welded on no bolts! so no changing the whole thing.
Nov 16, 2011 23:48:22 GMT
Take the shoes along to a decent parts factors - they will be able to help. My local branch of Partco in UK stocked stuff for most trailer makes. They were also able to get old shoes re-lined with new material if new stuff was not available any more.
purplevanman
Nov 16, 2011 23:53:25 GMT
re line was my next suggestion as thats what I am doing due to rarity costs for mine, over �50 per hub for brake shoes !!
bearings can be measured and matched easy enough.
bortaf
R.I.P photobucket
mdw
any recommendations for decent factors, in south essex area?
chess
They look like they are Mini / early Metro.
mdw
Nov 17, 2011 19:12:45 GMT
cheers boys definately looks like mini drum brakes gonna order the parts tonight. thanks for the help
Nov 25, 2011 10:06:18 GMT
Recently I've had to spend far too long working on trailer brakes which also involved detective work to find out what I had. So although it sounds as if mdw is now sorted, others might find these suppliers useful: www.trailertek.com/Good next day delivery, or if you're local (Micheldever Station, nr Winchester) very helpful & knowledgeable service. After lots of googling, I still couldn't identify what I had, but the chap at Indespension in Reading (Richfield Avenue) identified the rusty bits I showed him in an instant and had the £10 parts in stock (saved me cost of two suspension units which was the alternative) On another trailer, like Grunty, I was faced with the prospect of having to pay a lot (£80) for a set of brake shoes. That's almost against my religion. So, if you have a Lockheed braked trailer (metal rods going into the back plate) try : Wilmond Engineering at www.towingequipment.co.uk/acatalog/Lockheed_Brake_Spares.htmlBrake shoes for £40, much better. (Sorry for being boring, but this might help someone out. Let the normal program of interesting cars continue!)
