Nov 24, 2011 13:22:58 GMT
If no coolant then no worries as nothing to freeze and expand.
Dumping the water out of radiators over night used to be a common way of avoiding frost damage on lorries.
col
wut
Nov 24, 2011 13:26:12 GMT
aslong as all the inlet, exhaust, and coolant holes where bunged up, then there shouldnt be to much wrong with it. give her a good coolant and oil flush first though.
Onne
Nov 24, 2011 13:26:56 GMT
See if you can turn it over by hand... should be ok
1990 Mercedes W126 300SE 1997 Mercedes W140 S320L
Nov 24, 2011 15:08:33 GMT
The Pinto that Mike Ds just put in his Capri has been sat outside on my patio under a tattered bin bag for over a year and it's fine. If it's been covered then it'll probably be okay.
Nov 26, 2011 14:49:22 GMT
I swapped the engine from the thames van to the consul. The van had sat in the field for the best part of 6 years with the coolant and oil in it. I just changed the oil over , swapped the carbs and it sparked into life.
bortaf
All engine are diffferant but i started a Xflow after it was standing for 22 years with just fresh petrol and a battery and loads of pintos that have sat for a decade or so, only thing is after a good few years the stem seals crack appart other wise they have to be getting wet a lot to be knackerd usually.
R.I.P photobucket
mikeymk
'85 Polo Coupe S 1.6 16v
Nov 30, 2011 22:03:02 GMT
Sorry to throw in a post from the other side, but i bought a 44k mile 6yo Ibiza engine which had been fully covered and sitting on a pallet in a breakers for only a few months, i found rust spots in the bores which were too deep to hone out with stones, it needed an overbore.
I've bought loads of engines from breakers without a problem, so i don't know what happened with this one.
Nov 30, 2011 22:41:21 GMT
I would say you should be safe. The engine I bought for my old Mondeo was in a very damp container for around 2-3 months. It runs like a dream. We bought it with 70k on the clock (supposedly), it is now on 210k miles. That had no inlet manifold, bits of the filler cap down the manifold etc.
