Nov 23, 2011 18:37:17 GMT
Hi all, recently the Scirocco had started making a dull banging noise getting progressively faster and louder as I drive faster, I haven't dared go above 50, as it gets quite loud. It sounds just like a slightly loose wheel, but it's not. I had a peek and the O/S CV gaiter was split, and all the grease all over the inside of the wheel, so assumed it was a dried out and fubar'd CV joint. Changed the CV this evening, and the problem is still there, although slightly more quiet.
Anyone got any idea what it could be? it sounds like it's coming from the O/S, but I guess it isn't necessarily. Definitely drive train due to progressively worsening as I speed up.
Thanks in advance, Pete
1989 Mini MG 1275 ~ 1987 VW Polo ~ 1989 Citroen 2CV ~ 1998 VW T4 ~ 2006 Volvo XC70
Nov 23, 2011 19:18:40 GMT
Probably a curse word wheel bearing. turn the wheel by hand, I reckon you'll feel a notch
Nov 23, 2011 20:41:06 GMT
Both front wheel bearings are almost new and good, checked them first..
Nov 23, 2011 21:00:50 GMT
them boxes are cheap as chips if you think is fubard then get it pulled out and swap...
or what about the clutch my old mk1 cabrio golf started making bad noises and turned out it was the clutch friction plate the rivots had come apart making some bad noises because of it..even when me mot man said it was the gear box.
luck with problem
1995 mk3 cavalier 1.8i 1972 1200 beetle 2010 1.2 fiat 500 "sometime's" 2000 suzuki gsxr 600 srad
Nov 24, 2011 15:09:03 GMT
Got it on a ramp at lunch, everything seems to be fine, but there is quite a lot of float in the O/S drive shaft, more than there should be, and when you wobble it about, it makes just the noise.. will strip it tomorrow and investigate.
rodney
https://www.facebook.com/RD-vehicle-transport-and-recovery-services-525622614268010/
Nov 24, 2011 15:49:56 GMT
check your brake caliper bolts,.
facebook: rodney dean / rd transport
There was a distance washer missing from the drive shaft end, which explained the play in the shaft, fitted a new one and the noise is still there..
Nov 26, 2011 13:20:09 GMT
check the bolts that go on the inner cv, mine was making a bad clunk once, turned out 2 of the bolts my mate did up were loose....
Nov 26, 2011 19:22:22 GMT
Ok, thanks will check that. Tomorrow going to go round and check everything, swap wheels etc. If I still can't find anything it's getting a drive shaft and a wheel bearing.
Nov 26, 2011 23:09:21 GMT
Diff pin about to explode out of the side box?
Nov 27, 2011 10:26:37 GMT
Pretty sure it's not the box, I've had a few mechanics drive it and they all say it sounds like drive train , after the box that is.
Nov 27, 2011 23:49:15 GMT
Checked everything, changed wheels round, still there. Pass the shotgun.
RobinJI
Nov 28, 2011 21:12:51 GMT
It tends to be the 16v and cable change box's that's diffs give up, as it was only the late ones where they started riveting the diff together rather than bolting them. I'd be going with an inner CV joint my self. Mine killed both inner ones in my ownership and they sounded exactly as you've described.
It'd also be worth checking that the engine's central on the mounts, the end mounts are slotted about 3/4" and if it ends up too far one way it can cause the CV joints to bind as they can't take up enough the slack.
Nov 28, 2011 21:40:20 GMT
Thanks, I have a whole new drive shaft with both new CV's sitting here, also a bearing. If that doesn't fix it, I'm gonna go radio rental.
Nov 29, 2011 18:31:11 GMT
Sorted.. It was the inner CV I think. Thanks everyone for your help.
