povey
Nov 21, 2011 18:59:56 GMT
Little while Ago I brought a standard mk3 golf, it came with no head unit, and bow the times come to put one in I have a problem!
The headunit don't work! This is my problem as I know the headunit works! Does any one know the location of the fuse? Or Have any ideas on what could be wrong?
dubzi
Nov 21, 2011 19:11:07 GMT
Have you checked you've got 12V on the live feed?
Happiness ain't at the end of the road. Happiness is the road.
povey
Nov 21, 2011 19:48:39 GMT
Where do I check that from?
Rich
Club RR Member Number: 160
Mk3 audio help :-sRich
@foxmcintyre
Club Retro Rides Member 160
Nov 21, 2011 20:59:22 GMT
The wire that you connect the radio to.. Only shows ignition though, should be a permanent feed too. The fuse will be in the fascia fusebox. failing that, get a haynes
povey
Nov 21, 2011 21:07:54 GMT
Cheers mate Hopfylly I can dicipher that wording diagram I got the fuse tho lol I will check it now
povey
Nov 21, 2011 21:20:37 GMT
Bingo (ish) changed a blown fuse and now the power light comes on on the headunit, BUT I cannot turn the bugga on
tome30
Nov 22, 2011 12:09:41 GMT
There's a mixture of cable and wires that all need to be in the right place for it to work (obviously, stupid thing to say) and I've found from fitting many radios (usually as they get stolen!!!) trial and error is the key.
Sit in the car and while shoving wires into different holes, press the on/off button, eventually you'll get it working.
Rich
@foxmcintyre
Nov 22, 2011 21:15:56 GMT
There's a mixture of cable and wires that all need to be in the right place for it to work (obviously, stupid thing to say) and I've found from fitting many radios (usually as they get stolen!!!) trial and error is the key. Sit in the car and while shoving wires into different holes, press the on/off button, eventually you'll get it working. Sounds like a great way to put 13 volts through the amp and or speakers to me and ruin something You need to get a multimeter, a test light or at worst, a bulb on some wires and test for 12V permanent positive which needs to go to the YELLOW wire of your RADIO loom, a 12 Volt which is switched ON with ignition on which needs to go to RED and an earth which is BLACK. (assuming your radio has standard ISO connection) if you have no ignition feed you can double the permanent 12V into the red wire but the radio will always be on standby and may drain the battery.
povey
Nov 24, 2011 19:15:53 GMT
I'm not sure ifits the car or the headunit that's not playing the game! I have a power light to the headunit, but it's not turning on?
BiAS
Insert witty comment here
Club RR Member Number: 147
Mk3 audio help :-sBiAS
@cheeqi
Club Retro Rides Member 147
Nov 24, 2011 22:12:57 GMT
If the back of your HU has a din iso plug (two plugs in the lead, 1 power other one speakers) There should be a bullet connector in both the red and yellow wires, try swapping red to yellow and vice versa. Yellow at the head unit end should be permanent live Red at the head unit end should be switched live (live when ignition on) Sometimes head units don't like them being the wrong way round, worth a try, almost everything German I've ever had to put an aftermarket head unit in has needed the wires swapping. HTH
(car+wheels)-rideheight=WIN
povey
Nov 25, 2011 11:26:49 GMT
I need a new ignition switch :-) iv worked out, so off the the scrappy it is :-) cheers for all your help people,
