I've got a pair of Continental winter tyres (currently fitted to some shabby 7-spoke Merc rims, but they will be removed!) Very good tread depth, 6mm IIRC but I'll measure to make sure.
EDIT: Contis are 'Conti WinterContact TS810' with 5-6mm tread left. 615Kg (1356lbs) load rating
£50 for the pair
I've also got a 3rd winter tyre (also on a 7-spoke Merc rim, again to be removed) which is a dunlop with similar tread depth, I'll confirm later
EDIT: Dunlop 'SP Winter Sport' with 4-5mm tread remaining. Also 615Kg (1356lbs) load rating
£25 £20 as it has less tread than I thought
Finally I've got a 205/55/16 Michelin non-summer tyre (same rim story!). I'll check the tread depth later today and add it to the advert, I suspect it's 4-5mm from memory though...!
EDIT: Michelin Primacy HP with 4-5mm tread remaining, again 615Kg (1356lbs) load rating
£15
I bought these when I still had a Merc (a few months ago), but as my Lexus rolls on 18s and the GFs car, the Disco and Chevy run 15s (and the latter two would look silly with these tyres on...) I no longer have any use for them.
Feel free to insult me with silly offers or make sensible ones, the response you get depends on my mood
I can post a pair of tyres for a tenner if required. I'm shocking at sorting postage out though, so it'll take a few days if it's required! lol
£50 for the pair
£15
