Nov 16, 2011 23:27:48 GMT
hello i want twin stacked exhausts coming out of my bed and noticed how i want it they would be blowing into peoples faces. Because i running on a 1.8 GTI 8V with 32 34 DMTL weber my plan is to have a cherry bomber silencer middle box with a y piece straight from down pipe coming up with flxey hose what is the law on it AND WHAT ADVICE CAN PEOPLE GIVE ME
Well noise wise it's M.O.T testers discretion... As for the Hight, if you look at other caddys with stacks there quite high over the roof, probably to prevent blasting fumes in peoples faces... You best bet is to ask your local M.O.Ter. I can't see that there's any laws on where the fumes exit the exhaust as long as it's dangerous. I know you don't have to have any Gards or insulation on them so surly the Hight is irrelevant.
!!!SPREAD THE WORD OF MR PIKE'S RETRO EMPORIUM!!!
*not dangerous...
okay mate thanks sweet caddy by the way
Nov 17, 2011 12:23:42 GMT
Cheers you got any pics of yours on here?
sparkyt
selling stuff
Nov 17, 2011 12:50:19 GMT
If you doing stacked pipes your going have to put flappers on the top . Not for the mot just for the looks
Nov 17, 2011 15:05:43 GMT
Agreed! I want to put a TD in my caddy, put a stack with a flap and turn the fuel pump right up so it puthers black smoke out! Ha ha!! It would probably be aweful but it looks good in my head...
RobinJI
Nov 17, 2011 23:15:27 GMT
Flaps also help keep the rain out I'm fairly sure I remember reading on here recently that there is actually a law against having an exhaust that potentially exits near pedestrians faces. Can you not point them backwards or upwards so they're not pointing directly at the pavement.
Nov 17, 2011 23:50:06 GMT
i think there gonna have to be pointing up ward with the flaps
smurf
We did this to a few hilux's a while back
Easiest way I found was to use a Y splitter and 2 good lengths of flexi pipe with 90 degree ends to fit the base of the stack
Mounting the stacks is down to you and the way you want it styled As for the law, As Long as its not protruding outside the lines of the bed it should be fine, but theres less risk if they don't point right in peoples faces
Hope that helps
Last Edit: Nov 18, 2011 9:53:56 GMT by smurf
Laser cutting and cnc punching (up to 3mm stainless and ali, up to 6mm mild steel)
Mail me a dxf file and i'll get you a price Metal folding and custom fabrication service also available
