I'm after a 'skinny' clevis for a handbrake linkage. It needs to run 'through' the crossmember to get the reserve travel that I'd like, and I don't really want to make too big a hole in the crossmember for it. You can just about see in this photo: Prop is 8 mm above; exhausts hand about 15 mm below once the rear hangers are on; hole is centred on the clevis but there is play in the lever that it pulls and in this position its least likely to rattle... Any sources other than aircraft spruce/LAS aero? This is the type of thing I'm after but not 21.50 + VAT + post each if avoidable. Need not be new if there's a good scrapper to raid. The clevis pin on the handbrake lever is 8mm dia, and the pullrods are currently M8. Doesn't need LH and RH threads as the adjustment is not in that link. Pullrod could be swapped for 5/16" or 1/4" or M6 if needed but clevis pins need to stay 8 mm or 5/16" www.aircraftspruce.com/catalog/appages/an665.phpCheers, and a gratuitous glamour shot of the recipient: (anybody got some some XJR or Super-V8 rims?)
-- Marko
les509
Compulsive collector
Just thought I'd point out, BMW rims can look great on these too - my buddy had a set of 5 series sport rims on his , and it looked HAN
61 Jaguar Mk 10 67 Austin A60 Countryman 69 Morris 1300GT 77 Triumph 2500S 84 Mk2 Granada Ghia Est 86 BMW 635 CSi 87 BMW 635 CSi
scruff
carbuildersolutions?
1994 Lotus Esprit - Fragile red turbo with pop up lights. 1980 Porsche 924 - Fragile red turbo with pop up lights.
I spy a trend...
Try a trailer shop. Trailer brakes all use clevis like that of one sort or another.
Dez
Club RR Member Number: 34
Sourcing clevisDez
@dez
Club Retro Rides Member 34
Nov 16, 2011 10:06:59 GMT
Mcgill motorsport, theyve got a website now as well as ebay, www.mcgillmotorsports.co.ukeverything they sell is excellent quality, but very keenly priced.
Dez
Sourcing clevisDez
@dez
Nov 16, 2011 10:14:43 GMT
ive just looked on their size, and id buy this- www.mcgillmotorsports.co.uk/index.php?act=viewProd&productId=223then thread a short piece of thickwall tube with M 8 one end and 5/16 unf at the other (the tapping sizes are almost the same from memory) to act as a male>male adapter. its a pretty straightforward solution for less than a fiver.
Nov 16, 2011 10:26:31 GMT
Mcgill motorsport, theyve got a website now as well as ebay, www.mcgillmotorsports.co.ukeverything they sell is excellent quality, but very keenly priced. Wow, handy link! Never heard of them before but I'll certainly be making use. Cheers Dez.
markbognor
Club RR Member Number: 56
Sourcing clevismarkbognor
@markbognor
Club Retro Rides Member 56
Nov 16, 2011 12:19:37 GMT
I've used McGill quite a few times now for bits for the greenpower cars and they have always been excellent. Even replacing base spec rose joints with higher quality ones because they were out of stock of the cheepies on one order.
Nov 16, 2011 12:21:13 GMT
Magic, cheers!
-- Marko
Nov 16, 2011 20:59:50 GMT
PM me your adress and I'll send you a couple. We've loads of old control cables at work, aircraft quality on account on being from aircrafts
1994 Rover Metro 1994 Peugeot 405 Estate 1991 Rover Metro Gti 16v 2001 Fiat Seicento Sporting 1999 Fiat Punto 1.2 1994 Peugeot 106 Xnd (x3) 1991 Westfield 7 2004 Landrover 110 SW 2003 Seat Ibiza 1.9Tdi Sport 1959 Ford 107e Prefect 1992 Suzuki Vitara 2008 Skoda Fabia
