Mk 2 Cortina front suspension info!
Hello to all, sorry my first post is a question but was recommended to ask here from another forum
On the later suspension setup on the Mk2, there is a piece of rubber in the upper mounting that the top of the piston sits in but I want to know if the rubber is supposed to twist or the piston twits in the rubber!!
We are doing some work on a Mk2 and on one side the rubber twists in the upper mounting but the other side it’s solid! We are just trying to find out how it works.
If it helps the piece I’m talking about in on page 171 Fig.11.3 number 6 in the Haynes manual.
Thanks Mark
Thanks Mark
