micrat
Building a Kanjo styled Cinquecento :)
Nov 13, 2011 21:00:42 GMT
Hi guys, when my rover gti goes I'm going to be left with 6 alloys with good tyres, and I'm hoping to use them on whatever i get next...
they are 4x100 with a 56.1 centre bore, a lot of the cars I'm looking at are vag group, 4x100 57.1, would i be ok just dremelling out the extra mm?
probably an obvious yes, just wanted to check! been trying to get someone to run a golf round so i can trial fit tbh!
Nov 13, 2011 21:03:14 GMT
yeah - you only need half a mm all round, its sod all. If you can get in with a half round file you'll do a better job, probably quicker too.
Last Edit: Nov 13, 2011 21:03:39 GMT by cobblers
Nov 13, 2011 21:12:48 GMT
An end-of-drill flap wheel might make a tidier job than a dremel.
I've got Rovers.
Nov 13, 2011 21:14:07 GMT
An end-of-drill flap wheel might make a tidier job than a dremel. True story. That said, absolutely anything will make a neater job than a dremel!
micrat
Nov 13, 2011 21:17:20 GMT
cheers guys, i don't even have a dremel tbh! got a rat-tail file or a reamer think ill get the file on 'em for a tickle! have a feeling they could look kinda funky on the right car
You'll may well find they go on anyway, so i would try them first.
Ed@AC
We used a die grinder to enlarge the bore on some Mini one wheels (56.1) on my fiancée's Corsa (56.6). Just worked round the bore in a quick circular motion and then kept test fitting the wheels until the bore was enlarged enough to allow them to sit properly on the hubs. This tool: For this job:
Last Edit: Nov 14, 2011 8:26:17 GMT by Ed@AC
Automotive Connection - Whoever you are, whatever you drive.
After lots of experimentation I found that these were the best
micrat
Nov 14, 2011 10:24:37 GMT
cheers guys...
that corsa b on mini rims looks gorgeous! what a brill combo!!!
scruff
Nov 14, 2011 10:35:36 GMT
Are they not hub located?
1994 Lotus Esprit - Fragile red turbo with pop up lights. 1980 Porsche 924 - Fragile red turbo with pop up lights.
I spy a trend...
kevfromwales
the conrod's REALLY out the block now!
Nov 14, 2011 13:44:34 GMT
I took 2 mm off the centres of the rear wheels on the truck with a pair of rat tail files - it took frikking ages, but it was the only option, as it was the night before the MOT, and it one of those 'I'll just swap the back wheels and we'll be sorted - SH*T!' kinda moments
as I was doing it I was wishing I had a flap wheel / dremel / anything! - but it did work!
Almost on the road: b11 sunny breadvan, e36 tds, 325i skidcar,
nearly there: ford f250 tathauler, suzuki alto, u11 bluey
not for a while: ford pop, 32 rails,
not in this lifetime: ruby, '29 hillman
''unfortanatly I'm quite old and scruffy and in need of some loving. my drive shaft needs a new boot....''
Ed@AC
Nov 14, 2011 16:56:54 GMT
Thanks Micrat, shes very proud of it Scruff: Yeah they are hub located, that's why we took care to make sure we only took off what was needed to get the wheels on the hub and no more. Its a bit of a tight fit getting them on and off but by no means do you have to force them...
