Nov 12, 2011 20:11:03 GMT
Following on from Rev's example, I have been working on a Golf Mk4 this week that has some issues. Basically, it failed the MoT emmission test by a huge amount (CO 10%, HC 800ppm, Lambda 0.75) despite getting a service and fresh sparkplugs (and a new radiator and coolant temp sensor) before it went. Managment light is on too. First job was to run the trouble code - it came back as P0302 which is cylinder 2 misfire, no other codes stored. So I did a quick test drive, and ran some live data recording, which I made into graphs. This one is the two temp sensors, coolant temp rising as engine warms up, air temp remaining pretty stable. Probably not the fault. Speed, RPM, airflow and throttle position. Again, all looks pretty normal. I did notice PID 0103 (fuel system status) was reporting open loop/system fault through most of the trip, so it is looking like the suspect part is the #1 lambda sensor.... here's the trace for the two lambdas (pre and post cat) And it's a total mess! All over the place. Also, we still have the mystery misfire code to solve first. I ordered up another spark plug, and changed no 2, cleared the code, went for a drive. Car feels exactly the same but the MIL didn't come back on. Looks like a dodgy (new) plug. Today then - I took my new scope to work and tried some things out. Every component on the engine reads like it should, a relative compression test (cranking amps) shows no mechanical reason for no 2 to misbehave (confirming the dead plug theory) So it's time to crawl underneath (VW put the lambda sensor plugs under the driver's side floor) and probe some sensors. Just to recap, this is what a pre and post cat lambda reading should look like (borrowed from Rev Dick Deluxe's thread) and here is the one from today Yes, knackered zooming the waveform just produces noise, there is no switching happening at all on the front sensor which is sitting permanantly lean and the rear sensor is reporting the mega rich mixture coming out the back of the cat. I'll add another trace when I've swapped out the front lambda sensor. That way I can find out if the cat has had it too.
murran
Nov 12, 2011 21:57:12 GMT
oooo youve diagnosed a lambda sensor, good for you, bit tired now? id go have a lay down! you can just read the actual value. no need to produce graphs it should be obvious if the actual value isnt switching.
a good way i learned a while back with suspect lamdas is to introduce a small air leak in the inlet manifold (but not enough to upset the idle) like pulling the vac pipe off to the fuel pressure reg and see if the lambda sensor picks up on it. trying to compensate. also see if the co/hcs go down with a forced leaner mixture.
not meaning to put you down, I'm only joking!!!! very interesting this tho how other people go about fault finding like this, which mk4 engine is this btw?
we had a newish 3 cyl polo in a while back with a misfire (had another the same last week) both around 35k on the clock. the first one had been to another garage who fitted a new ecu! anyway after a bit of investigative work, the switching signal to the injector disapeers as it registers a misfire fault on that cylinder. clear the fault code it comes back but still misfires slightly til the ecu works out which cyl it is then cuts it again after 10 mins of driving. on checking the compressions/cylinder leakage that cylinder is about 40% down. on stripping it found no obvious problems till you look at the exhaust valve seat..... its gone oval....
what would be fun on here if we could post up interesting diagnostic jobs on here that we come across at work..... weve got a 58 plate audi a8 with a crappy electric handbrake I'm currently trying to fix, if your interested? its been to the dealer but the faults down to water ingress to the ecu so its not covered under warrenty. the ecu is fubar so weve fitted a new one coded it in etc but its still showing fauts to both calipers and the handbrake switch. all wires check out to the calipers supplies to the ecu canbus etc etc....
a couple from this week.
a volvo s60 with an owner thinking it needed a service cus the display said "engine service required" nope it was a kind of management light but the actual management light wasnt on. on checking fault codes, it had a dodgy clutch switch. 5v supply to it but signal wire is supposed to read around 1v clutch down and around 3.2v clutch up.... was reading 0.15v all the time clutch up or down..... new switch time!
an a6 2.5 tdi v down on power...... with a dodgy crank sensor managing to read crank position to run but not rpm (sensor does two jobs) and then needing a new airmass sensor. (guy actually rang up after picking it saying how fast it wasm asking if we had chipped it or something cus the difference was night and day!)
a '99 1.9 tdi a4 down on power on the motorway giving under boost faults. another garage said it needed a turbo cus of the variable vane not working properly. nope it need the vacuum control solenoid to the vv actuator as the vac was leaking back inside.....
a 2.0 fsi a4 avant that with the engine loom melted into the egr pipe....
a 2.0 tdi 170 with the common injector failure one call to the dealer and they picked it up and fitted new injecters foc then brought it back to us the next day for the customer to collect from us!!.....
i could bore you to death with this sh1t!
Nov 12, 2011 22:11:09 GMT
You sound like a diagnostic legend. I hope they're paying you well.
R.S. Autotech. Servicing/Repairs/Diagnostics.
Nov 12, 2011 22:11:55 GMT
8v 2.0. I take your point about the lambda, but although you can just read the value (and I suspected it right from the MoT) I wanted to have a play around and make sure, particularly with the misfire code going on too. I'm trying to learn as much as possible about how it all works. I have the time, and don't have a workshop manager breathing down my neck. Also, I like graphs It's about proving my theory before picking up the phone and ordering a new sensor. The audi handbrake thing sounds interesting!
murran
Nov 12, 2011 22:17:28 GMT
i know audis and vws well but I'm not all that with other cars but they're all the same pretty much.
I'm on 9.82 an hour lol. but not had a pay rise in 5 years.....
Nov 12, 2011 22:20:18 GMT
God, is that all I'm staying self employed!
murran
Nov 12, 2011 22:20:58 GMT
2,0l 8v? the pretend soft "gti"?
Nov 12, 2011 22:23:10 GMT
yeah, that's the one. It's a 5 door too.
murran
Nov 12, 2011 22:23:36 GMT
God, is that all I'm staying self employed! yep, fooking shocking is what it is! and thats a garage bang in sheffield city center that ive worked for most of my working life!
Nov 12, 2011 22:24:11 GMT
The whole point of scope diagnostics is it shows you what's actually going on in the engine rather than what an ecu sees or a scan tool tells you. With a scope I can diagnose pretty much any fault on any make of car. Show me a scan tool for less then a grand that can do that. In fact show me one for less than twenty grand that can.
Nov 12, 2011 22:28:16 GMT
Well said. What you have to remember about the live data from the ecu is that first, it could be wrong and second, it is quite coarse - you can't sample quickly, in the examples above I was getting a full report about every 7 seconds (but i was asking for a lot of data).
That is why I went and bought a scope. It just made far too much sense not to!
Nov 12, 2011 22:36:04 GMT
God, is that all I'm staying self employed! yep, fooking shocking is what it is! and thats a garage bang in sheffield city center that ive worked for most of my working life! Come down here and ill get you on 15 pound an hour minimum. That's if your as good as you say you are.
murran
yeah but once youve seen the same fault symtoms 5-10 times on similar vag cars with the related fault codes you don't need to check it out with a scope or multi meter etc cus you already know what the fault will be.
like a mk4 golf/sharan/touran tdi with the management light on but running fine.... fault codes for throttle body and cooling fan actuation 1.... you know the throttle body motor is full of oil the plastic cogs have worn out and its blown the fuse in the panel next to the battery which also runs the actuation for the fans. or the 05 plate tourans/early mk5 golfs with the traction light on.... you know its the abs pump/control unit brake. the fluid pressure sensor thats integral to the unit its reading 215 bar all the time...... audi tt's/audi a6s where the indicators are fooked up where they flash once or twice when signalling but the hazards work fine...... you know its the hazard light switch! mk4/mk5 golfs where the wipers don't work unless your going over 15km per hour....... you know the bonnet catch isnt reading either the bonnets open or closed, the micro switch is fooked and its not reading either closed (bonnet shut) or open circuit (bonnet open, and so the "your bonnets open" symbol doesnt come up on the dash pod) its reading some randon resistance in kohms all the time whether its open or closed.
you get to know what commonly goes wrong with a brand when you work on them all the time...... rarely are you surprised tbh.
murran
ive changed numerous engines on tts, s3s 1400 golfs took heads off allsorts. did a broken cambelt on a renault 1800 16v senic last week, head gasket on a k series lotus elise 3 weeks ago. 3 years ago i changed the engine on a 5 litre v8 auto merc sl cus of the engine being drown by flood water. not so long ago i did two cambelts on an v6 twin turbo s4 and a 2.5 tdi a6 in a day. you get quick at these things known the cars, having the right special tools and knowing what your doing.
you could strip a 1.8t engine completly down while i was blind folded throw all the nuts and bolts in the air. unblind fold me and id know where they all went.
I'm after a pay rise atm. i keep dropping hints and ive been for other jobs and been offered them but part of me thinks its better the devil you know..... maybe i should take a 2 week holiday next year if i don't get a pay rise? might make them realise they'd be a liitle fooked without me.
one thing that does wind me up is when they give a dianostic job to one of the other guys while I'm busy (oliver) they go read the fault codes, they come to ask me what they should check and look at..... i answer..... then oliver goes to the boss and regurgitates what ive told him looking all intelegent.... pisses me off!
murran
Show me a scan tool for less then a grand that can do that. In fact show me one for less than twenty grand that can. ah but thats it, I'm working with bosch kts 650 (works with most stuff with esi support). vws own vas 5052 licenced for vw, audi, seat and skoda (we have backing to code keys/stereos etc with online backing from germany on all makes etc) and do stuff that would actually blow your mind. autologic, we've bought landrover, porsche, bmw package. awesome stuff! I'm privlidge to be working with such diagnostic set ups. god knows how much it costs including updates renewing licences etc it must be 25k a year! if you ask me we don't make full use of all this diagnostic potential tbh. and ive not had the proper training in how to use it all which is a shame, its all in the job.
Last Edit: Nov 13, 2011 1:10:04 GMT by murran
murran
did I mention ive been a tester since just before computerisation too?
id jump at £15 per hour. if you can keep me busy?
Last Edit: Nov 13, 2011 1:19:09 GMT by murran
Ah, but.... I'm a lot more low level and hands on than that. I'm using an elmscan 327 and issuing commands via a serial terminal. No software, no diagnostics other than my brain. The live datalog was done with a quick bit of C programming - it asks for supported PIDs with 0100 and then queries them all in turn, logging to a csv file (comma separated list) for later analysis. Total cost to me? A laptop I already owned and a tenner for the elmscan.
Also, isn't the KTS650 the one with a digital scope built in? I had a play with one recently, nice piece of kit but ouch! expensive.
vws own vas 5052 licenced for vw, audi, seat and skoda (we have backing to code keys/stereos etc with online backing from germany on all makes etc) and do stuff that would actually blow your mind. Believe me, it wouldnt. I like autologic, we have that at the place where i do my day job. I can tell you the package we have for VW BMW and porsche costs over 20 grand alone. We also have a kts there but tbh i would rather use my snap on solus, its twice as fast and can read more codes than the bosch. I'm in a posistion where I've worked on mercedes sprinters and vitos for almost ten years now and i agree that 90 or 95 percent of the time you can diagnose them without even looking, but every now and then you get something that will throw you a bit and thats when you realise how important it is to be versatile and think outside the box. A good example is this from last week. A fiat scudo with a missfire from cold. No fault codes, nothing out of the ordinary in live data, relative compression good and glow plugs working fine. I scoped out the fuel pressure and injector signals and got this. The blue trace is injector current and the red is frp sensor. Zoom in a bit and the problem starts to show up. See the pattern of two flats followed by two big dips in pressure, that No 3 and No4 injectors letting in two much fuel. Two injectors and the problem is solved. Whats more we were actually able to look the guy in the face and say 'this is your problem', not 'we think if we change this it might get better'. Main dealers wanted to charge him over two grand for a pump and four injectors. The point i'm trying to make here is that fault wouldnt have shown up on any scan tool. Even a running leak off test wasnt conclusive. It showed no3 leaking off slightly more than the others but not enough that i would be confident in changing it.
murran
yeah its got all the functions of a fault code reader, tech support, scope and multieter. its all built in designed to save time plus you have tech support at the end of a phone that know the equipment your using like the back of their hand. tho i often find when you ring them up that you know more than they do..... telling you what i already know and asking you to ring them back when you find out whats wrong with the car your looking at. as theyve been out of the game at looking at faults with cars!
how did you check it was 3 and 4? pressure against injector trigger for each in turn? (I see why you are thinking about a 4 channel scope!)
