Nov 12, 2011 20:00:13 GMT
O.K thought I'd ask on here incase someone has a new suggestion or has experienced the same problem.
I have a wobble/vibration on my front end when I go above 40mph or turn LEFT only.
I thought it might have been a cv joint so replaced the whole n/s driveshaft, problem not solved.
Just put 4 brand new alloys, which have all been balanced so cant be a wheel/tyre problem.
It could be a diff bush, but want to see if anybody has anymore suggestions before the gearbox comes off. But usually this causes oil leakage and mines bone dry
Cheers Dave
Nov 12, 2011 20:17:13 GMT
what sort of car is it?
Nov 12, 2011 20:31:42 GMT
Saab 9-3 2ltr turbo
Nov 12, 2011 20:40:40 GMT
Knackered bush on the N/S lower wishbone then. (as a guess...)
Nov 15, 2011 21:37:30 GMT
Thanks for the reply.
Would you say its more likely something like a bush or ball joint than a diff bush then?
Nov 15, 2011 22:42:02 GMT
If by diff bush you mean gearbox mounting i would say its unlikley. When they go you tend to a clonk when the power is taken up and when changing gear. For a vibration you need to be looking further out towards the wheel. Ball joints or top mounts could also be to blame.
R.S. Autotech. Servicing/Repairs/Diagnostics.
bl1300
Nov 16, 2011 16:40:52 GMT
Id be looking at ball joints and suspension bushes personally. My first thought when reading it was wheel balance but you say thats fine. Also sounds obvious but are your tyres inflated to the correct pressure.
To test your ball joints lift the wheel and grasp it top to bottom and try to rock it. You shouldn't have much play. If it moves grasp each ball join in your hand and rock the wheel again you should be able to feel the play in the offending joint.
If your worried about Track rod ends then its the same procedure only holding the the wheel side to side rather than top to bottom. If you do that you might as well check the bearing as well spin the wheel it should spin smoothly without undue noise.
Current fleet.
Nov 16, 2011 16:47:49 GMT
Thanks for the info mate, I'll give it a try this weekend and let you know how I get on
Nov 16, 2011 19:24:07 GMT
If by diff bush you mean gearbox mounting I would say its unlikley. When they go you tend to a clonk when the power is taken up and when changing gear. For a vibration you need to be looking further out towards the wheel. Ball joints or top mounts could also be to blame. No I mean the actual diff bush in the gearbox mate where the input shaft goes into.
bl1300
Nov 16, 2011 19:30:49 GMT
If its on the input side of the diff I cant see why it would be more apparent when turning left as the input shaft should be turning at the same speed regardless. If what youre describing is what I think it is id wager that is pretty unlikely to be your culprit
Current fleet.
Nov 16, 2011 19:45:08 GMT
If by diff bush you mean gearbox mounting I would say its unlikley. When they go you tend to a clonk when the power is taken up and when changing gear. For a vibration you need to be looking further out towards the wheel. Ball joints or top mounts could also be to blame. No I mean the actual diff bush in the gearbox mate where the input shaft goes into. I would say its unlikley. What sort of vibration is it? You say its on the front but can you feel it through the steering wheel or does it come through the floor.
Nov 16, 2011 21:09:37 GMT
The reason why I suggested the diff bush is because there is apparently "excessive" play when the driveshafts are connected.
The wobble vibrates mainly through the floor, no vibration at all when I turn right or at low speeds, only when I go over say 40 and turn left.
I thought if it was a diff bush then surely there would be a wobble/vibration at any speeds and when I turn both left and right?
bl1300
Nov 16, 2011 21:37:16 GMT
If it was a bush on the right hand diff output shaft then it could cause the symptoms described but I still think its more likely closer to the wheels. As for an input shaft bush as you say id expect it to behave in the same manner weather or not its turning left or right as it should still be turning at the same speed regardless
Current fleet.
Dez
Club RR Member Number: 34
Nov 16, 2011 21:39:27 GMT
steering rack inner pivot/joint? i usually find its this if it only manifests itself when turning one way, or the rear wishbone bush as SOC suggests.
Nov 16, 2011 21:52:48 GMT
If it was a bush on the right hand diff output shaft then it could cause the symptoms described but I still think its more likely closer to the wheels. As for an input shaft bush as you say id expect it to behave in the same manner weather or not its turning left or right as it should still be turning at the same speed regardless Yeah makes sense mate.
Nov 16, 2011 21:55:44 GMT
steering rack inner pivot/joint? I usually find its this if it only manifests itself when turning one way, or the rear wishbone bush as SOC suggests. With it also happening under load going in a straight line I wouldnt have thought it would be the steering rack?
Nov 16, 2011 22:21:46 GMT
Reason I suggested the rear wishbone bush in the first place is because the 9-3 is to all intents an puropses a vectra, and vectras are very fond of munching the wishbone bushes and then pulling all over the road
