ikon31
I'm after a paint i can use on a pick up bed.
I want it to be hard wearing, its not going to get much abuse, (if any) but i want somthing that is kinda rubbery finish. I'm sure there is stuff out there, i've seen it used in the states before now.
Any ideas what i can use??
van life is the high life
Foxy
Making pink manly in the north!
I'm the handsome fella with the cheesy white specs or is that the cheesy fella with the handsome white specs?
smurf
I used grey industrial floor paint with a few handfulls of sharp sand thrown in
Nice and grippy too
Laser cutting and cnc punching (up to 3mm stainless and ali, up to 6mm mild steel)
Mail me a dxf file and i'll get you a price Metal folding and custom fabrication service also available
i have used UPOL RAPTOR feckin brilliant stuff £50 notes for 6 tins & it go's a long way, very hary paint, there is'nt alot any better out there for sure, & its overpaintable, the other advantage is you can by it in what they call ta tintable finish so you can add a colour tint to it so it matches the bodywork!
don't use any rubberised finish, it gets splits/tears & creates rust & probloms that are a ballache to fix
upol raptor is the stuff for the job fo-sho! i cant recommend it highly enough to be honest!!!!!!!
i like it so much i bought a 2nd kit of the stuff & its under the bed reday for any future motor
it deadens sound a fair bit too-don't cheap ot on other stuff, this stuff is a do once & you can forget about it-top stuff
Mini 998cc grp bonnet & boot, lightend shell, 6-point cage, soon to have a turbo on the 998 engine (t2 frm a r5gt) rs turbo intercooler, hoping to get 120ish bhp?
father is building a Mini Van 1330, 45 weber, 100bhp@wheels
'RIP' 1.8 Metro GTi, 15.23 1/4mile
oh it smells just like liqorice when you spray it too which is loverly, breath it in deep, long n deep-i pay lots of attention to heath n safety :OP just kiddin but it does smell nice
This UPOL stuff seems pretty good, but I have some questions! The tinter you add, does it have to be a specific type/brand or will any do? And as for painting over the top: What is the procedure for that? Another regular primer coat and then top coat? How well will regular paint/primer bond with the UPOL surface? I'm completely new to the painting cars business, so aim you answers at that level please Have a picture picture of a truck that definitely hasn't been UPOL'd
1990 BMW 318iS, 1971 Range Rover V8
bigt
Nov 10, 2011 16:04:18 GMT
I have had a pickup up bed sprayed by a company - think it was called LineX or something similar......cost a few years ago..around £200. I built a matching trailer for the pickup and used a DIY spray in liner - Protecta Kote - around £80. There was a difference and the price reflected that. I got both beds looking similar by using a tin of B & Q gloss over the trailer bed.
It really depends on what the bed is going to be used for.....for show....go DIY. For heavy use get it sprayed in by a pro......they can vary the thickness of the material for the real load luggers!!!
Last Edit: Nov 10, 2011 16:06:48 GMT by bigt
