I want to have a Branding iron made up to use for the woodwork in the other modifications thread.
HERE:
www.retrorides.proboards.com/index.cgi?board=othrmod&action=display&thread=115998
I suspect there will be an answer or two from the general group here.
Ideally it will be brass, copper or steel and be able to be fitted to an oldfashioned soldering iron (the heavy duty ones)
It could also be heated with a gas flame..... and then used on the piece to be branded.
Does anyone here work in a shop/business that could take a basic design and then laser cut it into a 35mm or1 inch steel/brass rod ?
If you do not do it, do you know someone who does, and what sort of cost it will be?
Thanks.
HERE:
Thanks.
