I've done a bit of fiddling with these engines before, but never had one in bits... now I have a very poorly C32 Laurel to cure - lots of painful sounding top end rattles (not just rattly tappet type stuff - proper death rattle!), and also clearly not running on 6 either.
I pulled the rocker cover off for an intial look the other night and noticed:
1/ Mechanically, it looks just like a 6 cylinder version of a chain drive Lada engine!
2/ None of the rockers have leapt off (had this on a Riva 1500, hence my familiarity with said engine)
3/ None of the valves appear stuck or broken
4/ Some of the cam lobes look a bit scored (do these engines ever have top end oil feed issues?)
5/ Valve clearances look ridiculous (as in, nobody ever checked or adjusted them)
So... questions:
1/ Any common faults / ideas?
2/ What are the correct valve clearances?
3/ Anybody have details of a good parts supplier for these engines? I am suspecting it will need a top end re-build really.
4/ Does the timing chain & associated gubbins have an actual or "best practice" replacement interval?
Have a couple of L series powered cars for carma:
4.bp.blogspot.com/_AlNoHq3Sz1c/SxDKl1RCZdI/AAAAAAAABmE/RbfadRQpj9c/s1600/nissan_skyline-2000-gt-r-kpgc10-1970_r2.jpg [/img]
So... questions:
