I arrived late and made the mistake of taking the spare parking spot beside the BBQ at a recent club getogether.
It was only afterwards, on the way home when I had to use the wipers I discovered my car was covered in a thin film of grease from the steam/smoke off the BBQ landing and condensing on my lovely paintwork.
Obviously I want rid of it but I don't want to damage the paint scrubbing it. Is a hot wash the only answer?
Hot steam wash with a snow lance would prob be your best bet.
Most haulage firms have em, just take a box of sweets or chocs in and ask the office staff.
Or hose pipe on the hot tap.
Any good shampoo mixed stringly enough should be okay - something like Duragloss 901. Alternatively, snow foam, or a weak mixture of a degreaser like Bilt Hambers Surfex HD should shift it. Try and get as much off via solution, rather than friction, i.e rubbing hard with a sponge, to protect the paint!
Try tar remover from accessory shop or if want a cheap option simply use diesel (red OK ) Then wash as normal. Paul h
thanks for the tips folks
Truck wash... it got dried out Coke off my van
Koos
bortaf
Truckwash but re seal the paint after cos if you use it neat it will take everything off including the top layer of paint
R.I.P photobucket
If it's grease from a BBQ then it's mostly fat, so try washing it with biological washing powder. Really good for degreasing but very gentle. And also well cheap.
Panel wipe as used for car refinishing,dead cheap and removes any grease or oil ect without damaging paint or trims
Well you will mess with these cars....
Mk4 golf gttdi highline. Mk2 golf 1.8T
