ok after closer inspection on my engine i found 2 things concerning me,
first one was ther water pump, theres a hole being blocked by a screw and tubing and i have no idea why?
water pump dosen't look in best of conditions maybe time for a replacement
second thing i found was a 'vacuum' pipe with a screw stuck in the end, I'm assuming this is out of the throttlebody front but when i fix it to there the engine idles really high, it runs ok with screw in tho maybee slight bit sluggish
