CIH
Oct 30, 2011 21:32:02 GMT
As mentioned elsewhere I plan to remove the repeaters which means removing some of the turn-signal loom. How can I remove two of the lights without introducing strange behaviour, such as lights flashing too quickly ?
I could refit a bulb and hide it, or somekind of resistor in place of the bulb but ideally I'd want to remove the redudant loom.
I presume it's controlled by a relay which could be swapped out for a 4-flasher rather than 6......if that makes sense ?
Copey
Oct 30, 2011 21:53:57 GMT
side repeaters draw that smaller amount of power it shouldnt effect the speed, didnt on my capri at any rate
will930
Decked K11 Micra - RetroRunner Mk2 Golf
Oct 30, 2011 21:56:57 GMT
I changed my side ones to led and due to them being low powered its does flash slightly quicker!
Oct 30, 2011 22:06:19 GMT
Basically you'll be removing 5W from a 47W system (5W from the 47W = 42W remaining across the relay = not a massive loss and the relay will only speed up a little)
This will mean a very slight increase in the rate of the flash but nowhere near as drastic as removing one of the main indicators (21W from the 47W = 26W remaining across the relay = very fast flash)
In other words, not a problem to remove the repeaters and the wiring completely.
Lopez
East Midlands
Oct 31, 2011 16:16:51 GMT
As above, almost no difference on my Manta with or without
CIH
Oct 31, 2011 18:55:51 GMT
Ah, thanks guys!
