tigran
In rust we trust. Amen.
Club RR Member Number: 142
Something for ECU bods.tigran
@tigran
Club Retro Rides Member 142
Aug 22, 2006 10:04:26 GMT
How difficult is it for an (electronics) clutz like me to put a luminiton system together. Is it pretty much following directions which they have on their site and forum? I am talking strictly of the chip/motherboard as I realise much bodging of 'hardware' coming up, but I am more capable of that - it's just the electronic tricka-ma-gadgetry that baffles me.
*goes on e-bay to find soldering iron*
Something for ECU bods.BenzBoy
@benzboy
Club Retro Rides Member 7
Aug 22, 2006 10:17:23 GMT
If you haven't done much soldering, I'd recommend buying a simple electronics kit before breaking out the soldering iron on the ECU. That's what I did before starting on my Megasquirt kit. Places like Maplin do them for a few quid, and it needn't be something daft like a light-up santa, you can get all sorts of automotive stuff too - I got an interior light courtesy delay switch circuit to practice on.
tigran
@tigran
Aug 22, 2006 10:22:40 GMT
Yeah I think that would be a good idea, ta.
P.S. I am getting my luminition and megasquirts mixed up. I meant megasquirt in my first post.
@benzboy
Aug 22, 2006 10:26:24 GMT
Ah, yes the Megasquirt manual is pretty easy to follow - I'm about halfway through mine but haven't had any time to finish it off yet The hardware is pretty easy to source too - a lot of the site is a bit US-focussed but it's all GM stuff, so most Vauxhalls have the bits needed. I think the only bit of hardware I need now is an IAT sensor as I couldn't find the right one. Well, that and a built-up engine to hook it all up it to ;D
tigran
@tigran
Aug 22, 2006 10:34:24 GMT
'sit destined for the mercedes?
Aug 22, 2006 10:35:17 GMT
soldering is easy but yeah - practise on something cheap first! I'd also recommend getting a half-decent temperature controlled iron (even these are only £20ish) to save extreme heat lifting tracks. Just steer clear of the £4.99 Aldi soldering irons and you'll be fine The most important electronics tip I can give is... the silver end of the iron is the hot one. You only do that once!!
@benzboy
Aug 22, 2006 11:02:34 GMT
'sit destined for the mercedes? yeah Having logistical difficulties at the moment. F*cking off to the other end of the country doesn't help speed a project along, I've found ;D
Aug 22, 2006 11:35:21 GMT
where are megasquirt kits from? I need one for project evils turbo unit
@benzboy
Aug 22, 2006 11:49:44 GMT
where are megasquirt kits from? I need one for project evils turbo unit I ordered mine from the States. TBH I think it's a needlessly complicated ordering process, and it took me a while to figure out what the hell I should be asking for! I got mine from www.glensgarage.com
Aug 22, 2006 11:53:33 GMT
Do a search for "Bill Shurvington" he is Mr Megasquirt over here and very helpful. He carries kits and built up ECUs and everything needed to get you going
Wideband Lambda controllers as well HTH Dom
tigran
@tigran
Aug 22, 2006 12:21:51 GMT
Bill (at) shurvinton dot fsworld dot co dot uk - this bloke?
Last Edit: Aug 22, 2006 15:17:27 GMT by tigran
tigran
@tigran
Aug 22, 2006 12:25:28 GMT
P.S. having a poke about diyautotune.com it shows that the difference between kit form and assembled MS II unit is about $250!
Yikes.
ImpManiac
Imps... Imps... Imps...
Aug 22, 2006 13:03:33 GMT
I got mine for the Chamois from Bill Shurvinton. I cheated and got mine built up. For building and testing both ECU and relay box, I only paid £50 extra - well worth the dosh, I think. I've never soldered up a PCB before and thought about it but decided to opt for reliability over kudos. We live and learn. Also got wideband O2 from Bill S. I'm
1966 Singer Chamois sprint/hillclimb car in white over blue two tone 1975 Triumph Stag long term project (over 20 years so far) in colour TBA 2003 Vauxhall Vectra GSi 3.2 in black sapphire
